JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Need help on IS200 induction kit!!
Pages (3): 1 2 3 Next
rsz325
16-08-2018, 11:15 AM
Hi
Last week i got sent a Greddy Trust induction kit bought for my IS200 2.0 1G-FE instructions in japenese - ok fine seems straight forward but its got couple of wires in the fitting kit a white and brown for the MAF sensor, does this mean the MAF sensor wire need extending ? i read up on induction kits for the IS200 weather its custom or off the shelf but i dont remember anyone mentioning needing to extend the MAF or any other wires ?? anyone help/or fitted a Greddy intake ? cheers
rsz325
16-08-2018, 11:15 AM #1
Hi
FunkMasterJay
16-08-2018, 11:51 AM
the 1G uses a MAP sensor dude.
Please take some detailed pics and post on here.
J
FunkMasterJay
16-08-2018, 11:51 AM #2
J
Not really important for the fitting process, but its an IAT (Inlet Air Temperature) not a MAF sensor.
And I would say almost certainly that the wires are to extend the sensor so it reaches it's new position in the induction kit.
My DIY induction kit thread mentions having to extend the IAT wires.
Edited 27-09-2011, 09:26 PM by sprinter2012.
16-08-2018, 11:51 AM #3
rsz325
16-08-2018, 12:46 PM
Thanks, er ok the IS200 dont use a MAF as i originally thought it was,
Heres a pic of the wires im on about i circled, this picture i found somehwere from the net as i havent even opened the bonnet of my car yet or even driven it this week let alone trying to fit it, lol but i circled the bits im talking about
[Image: 11111111111111111_G_001.jpg]
rsz325
16-08-2018, 12:46 PM #4
16-08-2018, 01:15 PM
There should only be one sensor wired into the original airbox (the one circled on the right) which is the one you need to extend. The tube on the left hand side is more than likely so you can attach the crank case breather to it.
Edited 27-09-2011, 10:50 PM by sprinter2012.
16-08-2018, 01:15 PM #5
17-08-2018, 02:16 AM
sprinter2012 There should only be one sensor wired into the original airbox (the one circled on the right) which is the one you need to extend. The tube on the left hand side is more than likely so you can attach the crank case breather to it.
I'm with Sprinter. (We're not in a Civil Partnership or anything, or even dating, I just mean that I agree with him!) The air intake temp sensor that was mounted in your airbox will need extending and inserting into the induction kit pipe somewhere along the way. I recently extended mine (OK, Ormi extended mine!) when I was fitting my supercharger, which includes an induction kit. Mine had to be extended by quite a lot, but yours may only need a couple of inches, depending on where about on the induction kit it mounts. The other section marked in the photo looks to be for the crank case breather.
Edited 28-09-2011, 11:53 AM by Stoney.
17-08-2018, 02:16 AM #6
17-08-2018, 02:33 AM
If its the same kit as in the pic mate, the wire should reach without extending it? they were made so you didn't need to modify any parts? :thumbup1:
17-08-2018, 02:33 AM #7
17-08-2018, 04:23 AM
Bandit If its the same kit as in the pic mate, the wire should reach without extending it? they were made so you didn't need to modify any parts? :thumbup1:
It does look very close to the factory position, doesn't it!
17-08-2018, 04:23 AM #8
17-08-2018, 04:49 AM
My induction kit has the sensor mounted in the 90* bend and it still doesn't reach. Sad
It may do if you strip back about 5 inches of the heat shrink/insulation tape on the existing loom. But it was easier to just add the wires rather than mess about with the rest of the loom.
Stoney I'm with Sprinter. (We're not in a Civil Partnership or anything, or even dating, I just mean that I agree with him!)
:lol::lol:
Edited 28-09-2011, 02:25 PM by sprinter2012.
17-08-2018, 04:49 AM #9
:lol::lol:
speedfreek
17-08-2018, 05:01 AM
Same here, funny that :laugh:
sprinter2012 My induction kit has the sensor mounted in the 90* bend and it still doesn't reach. Sad
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
17-08-2018, 05:01 AM #10
[/SIZE]
(Current project)
Views 331
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 702
06-11-2022, 01:49 AM
Views 1,199
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,168
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 461
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,724
04-08-2021, 04:34 AM
Last Post by cjoseph
