JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Speed Signal on manual IS200
Sam B
20-10-2018, 01:56 PM
anyone know the ecu pinout for the speed signal? ive heard its white with a blue stripe but want to be sure. Any info or input is appreciated.
basicly want to connect my Vehicle speed sensor on the gearbox up too the speed signal that travels to the clocks to get a MPH reading.
[Image: DWSIG2.jpg]
Sam B
20-10-2018, 01:56 PM #1
[Image: DWSIG2.jpg]
Sam B
20-10-2018, 01:58 PM
would be spot on if someone who has a IS200 manual around 99' jacked up too tell me the colours of the wires on the sensor to the rear of the box.
[Image: DWSIG2.jpg]
Sam B
20-10-2018, 01:58 PM #2
[Image: DWSIG2.jpg]
20-10-2018, 02:46 PM
Sam,
use the bahamut cars website for the pinouts.
though the ecu signal is fed from the speedo.
its goes from the sensor, to the speedo, then out a different wire to the ECU.
looking at the diagrams the sensor gets and ignition live to its pin 1 (red/blue)
the pin2 is red and is the earth,
pin 3 is the signal and is red/yellow.
the wire out is white/blue as you say from pin 13 to ecu 2nd plug back pin 28.
20-10-2018, 02:46 PM #3
Sam,
Sam B
22-10-2018, 07:19 AM
Thanks for your help stav, got it working today. Checked the circuit and red was live and red/blue was ground. Signal wire was spot on. Thanks again
[Image: DWSIG2.jpg]
Sam B
22-10-2018, 07:19 AM #4
[Image: DWSIG2.jpg]
22-10-2018, 08:46 AM
Hmm that doesnt seem right have a look here:
http://bahamutcars.free.fr/workshop/IS_9...ml?code=cm
but hey ho if it works
22-10-2018, 08:46 AM #5
Views 329
13-12-2023, 02:06 PM
Views 469
09-11-2023, 03:46 AM
Last Post by Dinho
Views 696
06-11-2022, 01:49 AM
Views 1,176
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,138
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 458
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,712
04-08-2021, 04:34 AM
Last Post by cjoseph
