JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza is,gs rx brake recall
davidjamesbattersby
23-10-2018, 02:38 PM
not sure if this is old news but seems to relate to the problem i think i have
20-10-2010: Lexus is launching two voluntary recalls in the UK, affecting its IS, GS and RX models. It is working with the Vehicle and Operator Services Agency (VOSA) to contact registered owners and keepers by letter to advise them of the procedure for taking their vehicle to a Lexus Centre or an Official Lexus Service Outlet for the necessary repair work to be done. The first recall concerns the brake master cylinder fitted to IS, GS and RX models built between February 2003 and November 2005. Lexus is aware that the seal between the brake master cylinder and the brake booster may turn in its seat, causing brake fluid to leak into the brake booster. In the very unlikely event that this happens, the driver will be alerted to the problem by the low brake fluid warning light. The brakes will continue to function normally for a significant time - over 200 miles of regular driving. Lexus knows of no accidents caused by this issue. The repair involves the replacement of a small seal and a check for any fluid contamination in the brake booster. If any contamination is found, the brake booster will be replaced. The job will take approximately two hours to complete, at no cost to the customer. Approximately 15,400 UK registered vehicles are affected by this recall.
davidjamesbattersby
23-10-2018, 02:38 PM #1
Tango
24-10-2018, 01:59 AM
My 2005/06 IS250 SE-L had the seal changed under recall in 2010.
Tango
24-10-2018, 01:59 AM #2
Views 359
29-07-2019, 09:39 AM
Views 1,572
20-01-2019, 01:03 PM
Views 803
23-12-2018, 08:17 AM
Last Post by jomo
Replies 33
Views 2,054
11-03-2018, 08:44 AM
Last Post by jomo
Views 505
18-12-2017, 12:28 PM
Last Post by Bandit
Views 572
24-08-2017, 09:41 AM
Last Post by dodgydave
Views 519
25-07-2017, 03:08 AM
Last Post by Duv
Views 630
15-07-2017, 12:44 PM
Last Post by posty
Views 752
16-02-2017, 02:44 PM
Last Post by Chri5
Views 567
01-12-2016, 11:10 AM
Last Post by James S
