JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Fog light brake light tail light mod **** up!!
jomo
21-12-2018, 06:45 AM
Ok i'v had the brake mod for a while now and got hold of a set of bulb holders to do the tail light mod, well did this today all works well till i run the car and i get and engine management light and the TRC light flashes when i rev the car?
I'v un-pluged the tail light mod and all's well again.
I wired the tail lights in the fogs to the number plate lights so i didnt have to run a long wire from the light cluster, i think i got the two green wires mixed up!
Any help would be great.
Martin.
jomo
21-12-2018, 06:45 AM #1
Martin.
21-12-2018, 08:29 AM
Maybe that's the issue wiring them to the number plate lights if you follow the walkthrough its not really a lot of wire and very simple and you won't have the error.
IMHO if the walkthrough works then use it as this is when issue can arise
21-12-2018, 08:29 AM #2
jomo
21-12-2018, 08:46 AM
Panic over Cpt mainwaring lol, just flipped the greens wires and all's good.
I'll post pics up later.
jomo
21-12-2018, 08:46 AM #3
21-12-2018, 10:57 AM
Mm be interesting to know why it happened though. Odd
21-12-2018, 10:57 AM #4
jomo
21-12-2018, 03:15 PM
Sparkystav Mm be interesting to know why it happened though. Odd
Why i got the wires mixed up, coz im a n00b lol.BlushBlush
I think that mixing the wires up sent power back through the fog lamps/bulbs giving the ecu a hard time.
jomo
21-12-2018, 03:15 PM #5
jomo
22-12-2018, 11:04 AM
Pic's time.....
Ok so i bought a set of fogs off ebay so i didnt have to chop my origs up.
But when they landed they looked like a$$.
[Image: 423812_10150501492206712_575506711_89034...6522_n.jpg]
So i had to wet n dry sand them to get the scratches out then polish them with my rotary polisher, add ended up with these :biggrin:
[Image: 396622_10150501492746712_575506711_89034...9829_n.jpg]
[Image: 428867_10150501492606712_575506711_89034...0769_n.jpg]
So the stock fogs have to be modded to get the tail/brake light bulb holder to fit, you just have to mill out a small section to get them to fit.
Standard fog.
[Image: 419229_10150501492456712_575506711_89034...1570_n.jpg]
Modded fog.
[Image: 409114_10150501492296712_575506711_89034...9672_n.jpg]
I used a burring bit in a Dremel, this left bits of milled plastic in-side the fogs so i gave them a wash out with soapy water and sat them on a radiator in the house.
I all ready had the brake light mod done so no need to run wires for that just a feed from the number plate blub live to run he fog tail light.
[Image: 421808_10150501492961712_575506711_89035...9609_n.jpg]
This was just temp to make sure all worked, i later used bullet/spade connectors to finish the job right.
Finished.
[Image: 402241_10150501683046712_575506711_89037...9382_n.jpg]
[Image: 417580_10150501684036712_575506711_89037...3965_n.jpg]
Comments welcome.
jomo
22-12-2018, 11:04 AM #6
Pic's time.....
Standard fog.
Modded fog.
Finished.
Comments welcome.
22-12-2018, 12:48 PM
Agree you just mod the bulb holder and saves modding the light cover
Maybe you should have done a walkthrough on how to clean up your lenses as mine could do with that treatment
22-12-2018, 12:48 PM #7
22-12-2018, 12:52 PM
Good job mate.
22-12-2018, 12:52 PM #8
Good job mate.
jomo
22-12-2018, 03:33 PM
Lexuspat Agree you just mod the bulb holder and saves modding the light cover
My original fogs that i took out need a polish but not too sure if they need wet sanding!
If they do ill do a walk trough for it.
jomo
22-12-2018, 03:33 PM #9
jomo
22-12-2018, 03:37 PM
Marsdendean You dont have to mod the fog light, you have to mod the holder.
I cut a 2 small lugs of mine with a stanley . . . . .
I didnt want to cut the holders as they were the only set i had, but if i cocked up the fogs i had a spare set.
If there was a walk through showing were the cuts were made on the holders then i would have done that, but i had no idea where or how much to cut off and didnt want to have to glue them in if it went t!ts up lol.
jomo
22-12-2018, 03:37 PM #10
Views 383
25-06-2021, 08:14 AM
Views 229
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 398
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 237
16-09-2020, 08:21 AM
Views 282
30-07-2020, 12:35 AM
Last Post by Dinho
Views 233
28-03-2020, 10:39 PM
Last Post by James S
Views 365
10-03-2020, 11:17 AM
Views 243
10-03-2020, 08:16 AM
Last Post by Colin G
Views 185
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Views 373
10-10-2019, 05:16 PM
Last Post by MrGash
