JapCarForum Car Manufacturers Nissan Modifications & Tuning Stagea Battery
Stagea Battery
Stagea Battery
09-11-2018, 12:14 AM
OK so driving to work today and the battery light came on, thought i know that sign i wont stop ill get to work then stop as i suspect it wont start again and hey what do you know it didnt lol
so there are 2 factors at play here is the alternator knackered if so great lol
or
is it just the battery which since i have had the car has gone flat once, i suspect its more the battery but my journey each day is a 45min - hour trip so im surprised that didn't give it enough juice......
So anyway what battery would be best to get for this beast lol halfords don't list a stagea battery so cant just click and reserve im pretty sure its the same as in a skyline but will need to check which one unless someone else knows.....
09-11-2018, 12:14 AM #1
or
09-11-2018, 12:48 AM
Match the cranking Amps on the label - IF there is still one there, then obviously make sure the terminals are the same way around. If there isn't a label there then I would go for a Skyline one - its a safe bet they are the same.
Sounds silly but Nissan (like Toyota are) will probably be cheaper then Halfords for batterys.
You know how to test the Alternator I assume?
09-11-2018, 12:48 AM #2
09-11-2018, 12:57 AM
just been out and started the car it managed to start under its own steam, however when the car is running it seems there is just under 12v being dumped into the battery however this is a 1996 car im wondering if need to rev it for the alternator to out put any current bit hard when its just me lol
09-11-2018, 12:57 AM #3
09-11-2018, 01:01 AM
Get your multi meter out Rabs. You can test charge voltage at the cigarette lighter socket - not ideal but doable.
09-11-2018, 01:01 AM #4
09-11-2018, 01:13 AM
yeah i know but im lazy nowadays
09-11-2018, 01:13 AM #5
09-11-2018, 01:36 AM
I'm sure that's not the attitude to have there Andrew
09-11-2018, 01:36 AM #6
09-11-2018, 02:34 AM
no your right so based on my previous statement i went out armed with multimeter and played with the throttle body etc
sure enough no power getting from a - b there is 12v just about present but no chargy chargy
however i did make a rooky error which i have never done before i have auto locking doors on a certain RPM well i was out side the car with the door open should have been fine except the door got blown shut and dint notice so i managed to lock the keys in car whilst it was running and had shut the bonnet now thats a secure car lol......
Anyway 20min later i now have the keys outside the car and its off to the garage after a jump start for a new alternator there goes this months profits.....
09-11-2018, 02:34 AM #7
09-11-2018, 04:36 AM
How much is a new alternator going to set you back but on the + side it won't happen again anytime soon
09-11-2018, 04:36 AM #8
09-11-2018, 04:41 AM
Your not fitting it yourself?
Is the auto box affected by removing power from its ECU? Some auto boxes need to re-learn their shift points after battery removal. Thus the invention of the OBD2 connected battery saver device.
09-11-2018, 04:41 AM #9
09-11-2018, 04:46 AM
i would normally fit myself as its not that hard and easy enough to get to but dont have the time at the moment Sad i have a good company round the corner that are normally very good so have just delivered it there and said quote me happy and walked away lol
09-11-2018, 04:46 AM #10
Views 1,258
16-09-2019, 09:56 AM
Last Post by Tooleys15
Views 395
16-06-2019, 01:42 PM
Views 787
12-06-2019, 06:21 PM
Last Post by Anees
Views 583
23-12-2018, 01:29 AM
Last Post by Mikey
Views 333
14-11-2018, 07:10 AM
Views 646
10-10-2018, 11:56 AM
Views 1,071
13-09-2018, 05:20 AM
Last Post by speedfreek
Views 648
18-04-2018, 02:18 PM
Last Post by Chri5
