Pages (17): Previous 19 10 11 12 1317 Next
phaebo
01-07-2021, 12:29 PM
Glad i could help.
I dont know where to find the caps. They should allready be on the injectors.
Maybe the person where you got the injectors from still has them.
Good luck finding them
phaebo
01-07-2021, 12:29 PM #101
Glad i could help.
01-07-2021, 12:31 PM
http://item.mobileweb.ebay.com/viewitem?...2004060355
If the above link does not work look in eBay for
Toyota denso top feed fuel injector service kit 6cyl
This kit I have used in both injector kits up to now and they work fine with no leaks
01-07-2021, 12:31 PM #102
S1SOFT
01-07-2021, 01:28 PM
http://www.ebay.com/itm/Toyota-Denso-Top...45&vxp=mtr
In these kit injector in the photo with a black cap. In this kit no black cap. Only filters and rings.
Buy the ring is not a problem, the problem is that, as said above - the lower ring with 1zz not sit tight in the engine block (to be loosely), and if you take the ring 1g, sits loosely injector.
I need only a black cap or install a ring 1g(23291-41010), without a black cap.
I found a similar case on the site euro.lexusownersclub.com There's a guy from Hamburg installed injectors 1zz (no black cap) on rings stock 1g.
S1SOFT
01-07-2021, 01:28 PM #103
phaebo
01-07-2021, 01:58 PM
Nice found ! Thanks for sharing
phaebo
01-07-2021, 01:58 PM #105
Daniel N
01-07-2021, 02:02 PM
Just buy them at Toyota Lexus dealer.
Seals 23291-41010
O-rings 90301-07024
Metal gasket between fuelline and rail 23232-41081 2 pcs
Daniel N
01-07-2021, 02:02 PM #106
Seals 23291-41010
O-rings 90301-07024
S1SOFT
01-07-2021, 02:10 PM
Thank you all for your answers.
On thursday I'll go and installed without caps. Delivery time will kill me.
If it is leaking fuel - installed stock injectors and I will wait for the pintle cap.
Daniel N fuel injectors with 1zz 2zz slightly thicker at the bottom.
S1SOFT
01-07-2021, 02:10 PM #107
Daniel N
01-07-2021, 02:31 PM
When I installed my yellow 2zz-ge injectors. The seals and o-rings went on like a glove.
Daniel N
01-07-2021, 02:31 PM #108
01-07-2021, 03:20 PM
The kit includes caps, as I mentioned above I used this kit twice and it is a full kit. I suggest to wait and use the caps! Better to be safe than sorry!
01-07-2021, 03:20 PM #109
S1SOFT
01-07-2021, 04:50 PM
Thanks for the tips. Found another way -
http://euro.lexusownersclub.com/forums/i...c=34881&hl
http://euro.lexusownersclub.com/forums/i...622&st=105
The guy bought the fuel pipe from the diesel Citroen (inner diameter 8, outside 10)How fast variant it's not bad.
Dimisbecause of the lack of free time (work) I just unprepared. There are additional problems with the rings.I'll try 2 options.
ORDER pintle cap. And try the fuel pipe.
S1SOFT
01-07-2021, 04:50 PM #110
 3 Guest(s)
 3 Guest(s)
Views 838
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 325
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 550
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 772
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 445
26-07-2022, 05:09 PM
Last Post by reganlives
Views 479
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 692
17-09-2021, 09:42 PM
Last Post by gsitlv
