Pages (17): Previous 110 11 12 13 1417 Next
01-07-2021, 05:23 PM
S1SOFT Thanks for the tips. Found another way -
http://euro.lexusownersclub.com/forums/i...c=34881&hl
http://euro.lexusownersclub.com/forums/i...622&st=105
The guy bought the fuel pipe from the diesel Citroen (inner diameter 8, outside 10)How fast variant it's not bad.
Dimisbecause of the lack of free time (work) I just unprepared. There are additional problems with the rings.I'll try 2 options.
ORDER pintle cap. And try the fuel pipe.
Ok I hope it works fine
01-07-2021, 05:23 PM #111
rob
02-07-2021, 06:42 AM
i saw there is a joker on ebay selling larger pulleys, claims he is the only person in the world making them :wink:
BUT he also says the original is 150mm according to his advert photo
http://www.ebay.co.uk/itm/Lexus-is200-Su...021wt_1161
the larger one looks larger than 160mm.
Its not TDI under another name is it ?
rob
02-07-2021, 06:42 AM #112
phaebo
02-07-2021, 07:39 AM
I have seen this product before. I think the price is way to much for a pulley. Almost 400 pounds for 1 single pulley. I got my 145 mm pulley from a guy named "pate" from euro loc.
I payed not more then 100 euro for a pulley.
This guy on ebay also sells single mass flywheels.
Does anyone know if they are good flywheels or better get better flywheel from a known brand.
phaebo
02-07-2021, 07:39 AM #113
rob
02-07-2021, 08:13 AM
I sent him a message saying pulleys are avail for £100 on euro loc
rob
02-07-2021, 08:13 AM #114
Daniel N
02-07-2021, 03:42 PM
I used the same guy "pate" on Euro loc for my 145mm.
Regarding flywheel. I'm waiting for my JUN flywheel. JUN flywheels are said to be good
Daniel N
02-07-2021, 03:42 PM #115
03-07-2021, 10:18 AM
Daniel N I used the same guy "pate" on Euro loc for my 145mm.
There are not many options for the 1GFE. Only jun and an Australia make lightweight flywheels. Btw you have to get used to the fact that you have to press a bit more the throttle when you start, jun lightweight flywheel does not like traffic and especially uphill starts, but you will like the aceleration
03-07-2021, 10:18 AM #116
Daniel N
03-07-2021, 04:29 PM
I hope I will get used to it :-)
Daniel N
03-07-2021, 04:29 PM #117
philip_98
04-07-2021, 12:42 PM
Sorry for opening this topic up again....im looking to get a larger pulley for my car, can i just buy one, bolt it on and go or do i also need to change other bits and pieces?
Cheers for the help
Philip
philip_98
04-07-2021, 12:42 PM #118
Cheers for the help
Philip
philip_98
04-07-2021, 12:49 PM
Just had another read through and seems i also need injectors...can anyone post a link to the ones im needing? cheers
philip_98
04-07-2021, 12:49 PM #119
phaebo
04-07-2021, 01:02 PM
Thats depnding on wich pulley you want to have.
I can only say that if you are going for a 145 mm pulley you can use 1zzfe injectors the part number is 23250 22040
You can also use 2zzge injectors then the car is runnin a bit richer in the higher revs
Injector part number is 23250 22030
phaebo
04-07-2021, 01:02 PM #120
 4 Guest(s)
 4 Guest(s)
Views 838
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 325
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 550
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 772
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 445
26-07-2022, 05:09 PM
Last Post by reganlives
Views 479
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 692
17-09-2021, 09:42 PM
Last Post by gsitlv
