Pages (17): Previous 112 13 14 15 16 17 Next
spud1973
08-03-2022, 08:38 PM
Buy 4 then 2 out of a 1.8 vvti that's what I did
spud1973
08-03-2022, 08:38 PM #131
marko45
09-03-2022, 03:29 AM
spud1973 Buy 4 then 2 out of a 1.8 vvti that's what I did
Yes i will do that.
Do you have an idea of à good price for those injectors ? Did you buy new or remanufactured or just used injectors ?
marko45
09-03-2022, 03:29 AM #132
Yes i will do that.
09-03-2022, 03:45 AM
Most people end up buying second hand as its alot cheaper but make sure there in good condition
09-03-2022, 03:45 AM #133
marko45
09-03-2022, 06:16 AM
What do you think of that http://www.ebay.com/itm/1-YEAR-WARRANTY-...f1&vxp=mtr
Expensive or not ? What about the seals, are they ok ?
marko45
09-03-2022, 06:16 AM #134
spud1973
09-03-2022, 11:40 AM
That's quite cheap I got all 6 for around £60 second hand and they have held up well
spud1973
09-03-2022, 11:40 AM #135
09-03-2022, 11:46 AM
Spud did u sell your standard pulley or never have one as im after one
09-03-2022, 11:46 AM #136
marko45
10-03-2022, 06:29 AM
I still have one question in mind. I have the Ypipe Megan racing but the OEM exhaust manifold. Is it a problem if I get a 145mm pulley ? Did you guys de-cat your exhaust manifold ?
marko45
10-03-2022, 06:29 AM #137
phaebo
10-03-2022, 06:49 AM
Did you get my pm marko? As i am not sur if it was send correct.
And yes i did de cat my exhaust manifold. It is better if you upgrade the pulley because the heat from the exhaust gasses will melt your pre-cats soon or later.
You have to open the manifold and pick out the cat then weld it all back together.
phaebo
10-03-2022, 06:49 AM #138
marko45
10-03-2022, 07:05 AM
Yes i got it phaebo thx very much.
I was sure it was better to do it but I did not want to do it because of the MOT ! But I do not have the choice I guess. I will do it and put back the OEM Ypipe every two years for the MOT !
phaebo Did you get my pm marko? As i am not sur if it was send correct.
marko45
10-03-2022, 07:05 AM #139
phaebo
10-03-2022, 07:08 AM
I got the same problem. I have to put my cat back in every year. But you rather want to put back in the pipe then you get melted pre cats.
phaebo
10-03-2022, 07:08 AM #140
 3 Guest(s)
 3 Guest(s)
Views 838
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 325
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 550
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 772
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 445
26-07-2022, 05:09 PM
Last Post by reganlives
Views 479
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 692
17-09-2021, 09:42 PM
Last Post by gsitlv
