Pages (17): Previous 113 14 15 16 17 Next
lex2oos
10-03-2021, 11:24 PM
can someone please take clear pictures of standart 130mm pulley? I am looking for one and I have found some mercedes pulleys that look like they could work, but I cant find good pictures showing tte 130mm pulley, so I cant compare...
A shot from front, back and side would be great.
thanks!
lex2oos
10-03-2021, 11:24 PM #141
thanks!
marko45
21-03-2021, 12:24 AM
I have just received my 1zz injectors (remanufactured with new seals and o-rings http://s23.postimg.org/cp5vt4my3/IMG_3246.jpg
My question is: are these seals and o-rings the good ones for the IS200 or only for the Toyota Celica?
marko45
21-03-2021, 12:24 AM #142
phaebo
21-03-2021, 01:48 AM
I used the oem is200 ones because they were slighly tighter then the celica ones. But i think they also seal well
phaebo
21-03-2021, 01:48 AM #143
daveo
21-03-2021, 01:56 AM
i am making pulleys to order. add me on facebook "lexibreak" and you will see them Smile
daveo
21-03-2021, 01:56 AM #144
marko45
21-03-2021, 02:05 AM
Does anyone here used the seals of the celica for their injectors? Any leaks with them?
marko45
21-03-2021, 02:05 AM #145
jeorje_2000
19-11-2021, 05:50 AM
Hello,
Are still available the photos with the retainer rings welded by TIG?
I can not find them, thank you
jeorje_2000
19-11-2021, 05:50 AM #146
Hello,
jeorje_2000
19-11-2021, 06:22 AM
Daniel N Hi Phaebo
I used a hydraulic press. It is a must when doing this rebuild.
Yes I used the retainer rings by TIG welding them.
I have a bit of photos of my rebuild on a Danish car site. Heres a link http://www.bilgalleri.dk/fotoalbum/tunin...renovering
You may have to register :-(
Hello,
jeorje_2000
19-11-2021, 06:22 AM #147
Daniel N Hi Phaebo
Hello,
196
22-06-2022, 04:55 AM
hi guys, has anyone got a dyno reading for 145mm pully with 2zz-ge injectors (yellow ones) and GREDDY EMANAGE BLUE e-manage ecu ready to buy all parts and get a map but hopeing for some readings before i go and do it.
lexusdaydreaming
22-06-2022, 04:55 AM #148
196
29-06-2022, 06:56 AM
doing some extra reading and noticed the 2zzge injectors run rich in the high revs, would it be better to get 150mm pully rather than 145mm with those injectors so it runs smoth throughout all revs with same a/f ratio? please can i get a reply as i am not too sure.
lexusdaydreaming
29-06-2022, 06:56 AM #149
phaebo
29-06-2022, 07:09 AM
With the 145 pulley you can use the 1zzge green injectors and it will run perfect.
With the 2zzge yellow injectors you need a piggy back or stand alone ecu because it will throw a check engine light. The ecu has to pull too much fuel so the fueltrims will be to much negative that it throws a cell. in other words it is just too much fuel to handle.
I think the max is 145mm pulley with the green injectors. If you go bigger with the yellow injectors you need a piggyback ecu to handle the fuel.
You can use the yellow injectors with 150-155mm pulley for sur. With piggyback.
I think with the 160mm pulley you need bigger injectors. The ones dimis was using. Part nr 23250-28080
phaebo
29-06-2022, 07:09 AM #150
Views 806
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 319
01-07-2022, 12:38 PM
Last Post by lexusdaydreaming
Views 543
14-09-2021, 07:43 AM
Last Post by P.Lindblom
Views 755
09-08-2021, 10:35 PM
Last Post by Jimbob-T-Lex
Views 432
26-07-2021, 11:20 AM
Last Post by reganlives
Views 464
30-03-2021, 03:26 PM
Views 402
13-03-2021, 05:38 PM
Last Post by deccie22
Views 666
17-09-2020, 03:53 PM
Last Post by gsitlv
