JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications is200 oil water fead return pipe pickys
18-03-2019, 08:08 AM
im not sure what your trying to get round?
the tank is still sealed when you put a return in, you just have a second line going to it.
18-03-2019, 08:08 AM #11
john wan
18-03-2019, 08:13 AM
putting a hole in the assembly lid
john wan
18-03-2019, 08:13 AM #12
john wan
18-03-2019, 08:15 AM
and drilling into the fuel rail like this fella http://my.is/forums/f114/fuel-return-sho...st-298869/
john wan
18-03-2019, 08:15 AM #13
18-03-2019, 08:29 AM
hmm wonder if a 1ggte one would work, that already has the holes for a return line in the rail. could you measure between each injector on your engine see if it matches the 1ggte at all.
18-03-2019, 08:29 AM #14
john wan
18-03-2019, 08:37 AM
yeah i can get out there in a hour or so i got a regulator like this one isnt it just as easy as connect up the small barbed fitting at the top and feed a return back to the tank?
http://www.ebay.co.uk/itm/Universal-Adju...500wt_1202
john wan
18-03-2019, 08:37 AM #15
john wan
18-03-2019, 08:49 AM
or being as i want is300ish bhp get a is300 fuel regulator ?
john wan
18-03-2019, 08:49 AM #16
18-03-2019, 09:04 AM
The guy on my.is had an IS300? Or it's certainly in the IS300 section anyway. According to my parts diagram there's a bolt in the fuel rail that comes out, is that not the case? That's how it is is on the LS.
18-03-2019, 09:04 AM #17
john wan
18-03-2019, 09:08 AM
Quote:
does anyone have pics on where to tap into the fuel rail. also what size tap.
You'll drill and tap it on the emboss'd area near cylinder 1 this is what it says eh
john wan
18-03-2019, 09:08 AM #18
18-03-2019, 09:10 AM
Yeah, that guy's talking about an IS300 though isn't he? The IS300 has a sealed fuel rail. From looking at my Toyota parts catalogue, the IS200 has a bolt in the end of the fuel rail you can remove. It might be wrong, it wouldn't be the first time the picture in the parts catalogue has been incorrect.
Edited 28-04-2012, 06:45 PM by toxo.
18-03-2019, 09:10 AM #19
john wan
18-03-2019, 09:13 AM
ill have to go out and poke around cant at the mo an lookin like i might not till tomorrowSad
john wan
18-03-2019, 09:13 AM #20
Views 1,767
05-07-2023, 05:08 AM
Last Post by damtrx
Views 827
17-04-2023, 03:51 AM
Views 1,420
05-04-2023, 03:19 AM
Last Post by damtrx
Views 741
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 304
29-11-2022, 03:38 AM
Last Post by phaebo
Views 401
30-04-2022, 06:27 AM
Views 604
27-04-2022, 12:45 PM
Last Post by oedipus
Views 695
19-06-2021, 12:50 PM
