JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Fitting the E-Manage Ultimate
22-05-2019, 12:45 PM
Everything except the ignition. You need it on 12v. All the diagrams for the IS show it as 5v but I had the same problem. It's like it's not man enough or something and needs to be the 12v setting.
Everything else looks right. Try moving that jumper and firing it up.
22-05-2019, 12:45 PM #11
S
22-05-2019, 01:05 PM
I was afraid you would say that!
I can't believe I spent 12hours wiring it in for 1 jumper to not be in the right place!
Gutted +rep!
S
22-05-2019, 01:05 PM #12
Gutted +rep!
S
23-05-2019, 07:53 AM
right here is my diagram, I havent had time to re-do it on word but its readable.
the 'X' s mean a cut in the wire and the two angled lines mean the wire is hosted on. the "GR#" means "Greddy Wire #".
The wires im least sure about are 15&22 - Greddy describe them as 'Airflow1 Voltage Input' and 'Airflow1 Voltage Output' Ive got them wired into the "Intake Temp Signal" is this correct?
[Image: IMAG0352.jpg]
here is the wire table from Greddy:
[Image: greddyemanage2.jpg]
S
23-05-2019, 07:53 AM #13
23-05-2019, 10:29 AM
No they need to go to the map sensor, same wire the black box breaks normally.
23-05-2019, 10:29 AM #14
S
23-05-2019, 12:09 PM
thanks Stav!
Do you know what Greddy wires 31 (Analoge Voltage Input) and Greddy Wires 37 (analoge voltage output) do or where they should be wired, my guess was to control VVTi?
S
23-05-2019, 12:09 PM #15
thanks Stav!
23-05-2019, 01:01 PM
Looking at the manual you don't need them. Unless your doing complex mapping within a certain throttle range or something?
23-05-2019, 01:01 PM #16
S
23-05-2019, 01:14 PM
Excellent, ill just tape them up Smile
thanks again Stav - do you know if the Greddy 2 step limiter works with the 1GFE?
Edited 03-07-2012, 10:50 PM by S.
S
23-05-2019, 01:14 PM #17
23-05-2019, 01:18 PM
I think it can do, Never got it working myself though.
23-05-2019, 01:18 PM #18
S
23-05-2019, 01:43 PM
Excellent again! That's what I'm looking forward to playing with the most! Smile
I saw in YouTube you got the 2step working on your G4 storm!
S
23-05-2019, 01:43 PM #19
23-05-2019, 02:26 PM
Lol that's easier to do though, it's antilag launch control just a simple setting to set up.
23-05-2019, 02:26 PM #20
Views 597
27-02-2020, 06:01 AM
Views 537
16-06-2019, 10:21 AM
Last Post by S
Replies 36
Views 2,013
14-10-2018, 11:50 PM
Last Post by Bandit
Replies 23
Views 1,738
12-06-2018, 06:03 AM
Last Post by lookatmybiceps
Replies 74
Views 4,111
05-04-2018, 08:11 AM
Last Post by bounty`
Views 1,493
01-01-2017, 06:54 AM
