JapCarForum Cars, Cars, Cars! Project Cars Mazda 323F BA - 1.8 Turbo
323F Rock
28-08-2019, 12:14 AM
Carbon bonnet on:
[Image: IMAG0283.jpg]
[Image: IMAG0287.jpg]
At home in time for Japfest 1…. Alternator issues… over charging…
[Image: IMAG0296.jpg]
[Image: IMAG0298.jpg]
Decided best bet as the 1.5 alternator is controlled by the ECU and the 1.8 isnt we should swap the alternator over… hey presto its works still another day at the garage including drive shaft removal….
[Image: IMAG0315.jpg]
[Image: IMAG0316.jpg]
[Image: IMAG0317.jpg]
New De-cat:
[Image: IMAG0382.jpg]
At Thor:
[Image: 256029_10150243265867556_172773622555_71...9950_o.jpg]
Having the suspension set up:
[Image: IMAG0380.jpg]
[Image: IMAG0381.jpg]
[Image: IMAG0385.jpg]
[Image: IMAG0386.jpg]
And finally back to the shows, at Japfest 2
[Image: 95555651.jpg]
Some massive thanks you’s go out to
Paul for giving us the space to do the engine swap in his garage.
Chi AKA Lantis for preparing a super awesome engine!
Andy aka AndyM for helping out in he garage when needed
Matt aka…. Matt without your help she wouldn’t have started first time!
Grayson Thermal Systems for the One off CAC and Oil Cooler
Black Performance for Ceramic Coating the manifold, hotside of turbo and down pipe.
Thor Racing for tuning the engine to 275BHP at the wheels and 315BHP at the flywheel @ 1.2Bar (quick change of the spring in the external waste gate and we should be able to produce up to 1.8Bar)
Aline Alignment great place for 4 wheel alignment, definately know their stuff!!
Our other halves for letting us go AWOL most weekends
There is bound to be some that I’ve forgotten! Please tell me ASAP and I’ll add you on! :cheers:
There’s still a lot of finishing up to do, mainly interior wiring (Nathan’s Job) and body work the bumper has always needed a respray but will have to wait for funds to allow as we’re now broke…..
Thanks for looking
Lee
[Image: IMAG0091.jpg]
Nathan
[Image: DSC02401.jpg]
323F Rock
28-08-2019, 12:14 AM #11
Carbon bonnet on:
New De-cat:
At Thor:
Thanks for looking
Lee
Nathan
323F Rock
28-08-2019, 12:28 AM
Sat Aug 20, 2011:
did some work on plugs today, i took the lower half of the dash board:
[Image: IMAG0438.jpg]
took the ashtray out
[Image: IMAG0433.jpg]
then i bent up some aluminium and cut some holes and most of the internals of the ashtray and mounted the plugs:
[Image: IMAG0443.jpg]
[Image: IMAG0436.jpg]
[Image: IMAG0434.jpg]
picture with the wires in:
[Image: IMAG0437.jpg]
[Image: IMAG0439.jpg]
Aux in for audio and video and usb port for pluging into the ECU for tuning
not finished 100% still need to polish the aluminium up and wire it in!
Big Grin
323F Rock
28-08-2019, 12:28 AM #12
Sat Aug 20, 2011:
Big Grin
323F Rock
28-08-2019, 12:29 AM
Wed Aug 31, 2011:
updates!! Big Grin
new horns:
[Image: IMAG0445.jpg]
[Image: IMAG0452.jpg]
[Image: IMAG0451.jpg]
and painted CAC brackets:
[Image: IMAG0477.jpg]
[Image: IMAG0475.jpg]
[Image: IMAG0478.jpg]
Cam cover removed for a bit of tidying up:
[Image: IMAG0446.jpg]
[Image: IMAG0447.jpg]
[Image: IMAG0448.jpg]
[Image: IMAG0449.jpg]
[Image: IMAG0472.jpg]
one door card wrapped 3 to go!
[Image: IMAG0491.jpg]
323F Rock
28-08-2019, 12:29 AM #13
Wed Aug 31, 2011:
updates!! Big Grin
new horns:
323F Rock
28-08-2019, 12:34 AM
Sun Apr 15, 2012:
hi guys,
we had a small oil leak seeping through the bell housing and engine, we decided it was the crank shaft oil seal so we decided to pull the engine out and sort it before the show season and track sessions
[Image: IMAG0903.jpg]
[Image: IMAG0904.jpg]
[Image: IMAG0905.jpg]
[Image: IMAG0906.jpg]
[Image: IMAG0907.jpg]
[Image: IMAG0911.jpg]
[Image: IMAG0912.jpg]
There is hardly any friction material left on the clutch! the rivets have just been skimmed Sad
[Image: IMAG0913.jpg]
[Image: IMAG0914.jpg]
Bits to buy:
pilot bearing for flywheel
flywheel
thrust bearing
Uprated Clutch kit
all to be done before Japfest 1 12th May :ohmy:
323F Rock
28-08-2019, 12:34 AM #14
Sun Apr 15, 2012:
hi guys,
Bits to buy:
flywheel
thrust bearing
Uprated Clutch kit
323F Rock
28-08-2019, 12:36 AM
Mon Apr 30, 2012:
[Image: IMAG0939.jpg]
[Image: IMAG0940.jpg]
[Image: IMAG0941.jpg]
[Image: IMAG0943.jpg]
[Image: IMAG0945.jpg]
[Image: IMAG0946.jpg]
[Image: IMAG0947.jpg]
[Image: IMAG0949.jpg]
[Image: IMAG0950.jpg]
30th April! a bit closer to Japfest but then engine is still in the garage.... Confusedhock:
323F Rock
28-08-2019, 12:36 AM #15
Mon Apr 30, 2012:
323F Rock
28-08-2019, 12:37 AM
Sun May 06, 2012
6th May we mangaged to get the engine back in Big Grin and mostly piped up,
[Image: IMAG0954.jpg]
[Image: IMAG0955.jpg]
[Image: IMAG0953.jpg]
also fitted our oil thermo stat Big Grin
[Image: IMAG0951.jpg]
Big Grin
323F Rock
28-08-2019, 12:37 AM #16
Sun May 06, 2012
Big Grin
323F Rock
28-08-2019, 12:38 AM
Sun May 06, 2012:
bits left to-do:
fit oil cooler - done
fit all charge air pipe work - done
fit battery - done
connect remaining wires - done
fit spark plugs - done
fill with engine oil - done
fit front bumper - done
fit strut brace - whoops forgot this... :oops:
reconnect drive shafts - done
top up gearbox oil - done
reattach bottom ball joints - done
bleed the clutch - done
fit bonnet - done
fit wheels - done
fill with coolant - done
run engine - done
bleed coolant - done
check & test some interior wiring - done
test drive - done
bed clutch in (500 miles) still to do Big Grin
Had a good 12 hour day on 7th July!! and completed all the above!
Big Grin
323F Rock
28-08-2019, 12:38 AM #17
Sun May 06, 2012:
bits left to-do:
fit battery - done
fit bonnet - done
fit wheels - done
run engine - done
test drive - done
Big Grin
323F Rock
28-08-2019, 12:39 AM
made it to Japfest 12th May
[Image: IMG_0049.jpg]
[Image: IMG_0062.jpg]
and Japfest 2
[Image: fairford20121697.jpg]
Big Grin
323F Rock
28-08-2019, 12:39 AM #18
and Japfest 2
Big Grin
323F Rock
28-08-2019, 12:40 AM
Saturday 4th August
Blyton Park Track Day organised by Mazda on Track!
What a fantastic day! Great organisers and track.
There were mainly VW polos and BMW M3s there but there were a couple of mazdas
PLUS!!! - I have to say a MASSIVE MASSIVE Thank you to my Dad (Lee) as this was the first time I (Nathan) have driven the car other than at 5mph around some shows! Braver man than i am! All i can say is wow wow wow Confusedhock: we've built a fantastic car, its so controlable (managed to find that out once or twice ) and the power is immense! As it was the first time i have driven the car properly i left her in Low boost, Dad had her on High boost though for his sessions and was lapping about 4 seconds quicker (timed on Racechrono App using phone GPS) than me as he was also carrying higher speeds through the corners.
2 hour drive from home to the track - 8 "sessions" (20ish mins each) in total - 2 hour drive home and she never missed a beat!! (despite us taking enough tools to do a complete strip down!)
It would have been possible to have more track time as it was open pit lane but Dad (Lee) wasn't feeling great and is suffering from the flu so we "took it easy...ish" (spent all day sunday in bed)
We had a couple wiggles on track due to driver error but driving by the seat of you pants means you could feel it have 5 mins to think about it then correct it with no major problems! Dad out braked himself on one chicane, so we went straight through. It was on the last session of the day we think tiredness was setting in by then as we were both shattered by the end of the day its very tiring!
Brakes were well and truley tested, (smoking at one point) and they held up well! The red paint on the calipers is now black though :oops: When these pads are done i think we will be looking at yellow stuff pads as a replacement just so they cope better with the heat!
The brake cooling ducts we added for Japfest 2 worked well as when one session came to an end due to red flag, the brakes were smoking but every other session we had a cooling down lap using little to no brakes and they were much cooler!
Theres a great right left sweeping section which you can take flat out, but i only managed half throttle feathering the pedal slightly! there are a few straights that you can open the throttle up think we managed a top speed of 86mph recorded on the Racechrono App so not sure how accurate it is, might look at a seperate GPS receiver.
During the lunch break the organisers changed the layout of the track, added a smaller, tighter, more technical section with a hair pin turn which just kept the day interesting! 2 different tracks is not something that every track day can offer you!
I managed to get a couple pictures which i'll get up soon!
One thing on the todo list is to get a camera mounted to the car so we can have some video!
Also the weather was great, dry all day apart from 5 mins where we had a few spots of rain while i was out on track, but it soon stopped and then we had glorious sunshine!
All in all the best day out in the car we've had for pure driving fun!
I'd fully recommend a track day to anyone!
Cheers
Lee
Nathan
couple of pics here:
http://www.clubpolo.co.uk/forum/index.ph...586&st=225
have to register though :?
[Image: 2012-08-04_19-21-21_187.jpg]
The "greenstuff" pads are now black stuff and the red paint has burnt off to black as well :lol:
[Image: 2012-08-04_19-20-47_302.jpg]
These were taken when dad was out with the instructor for a 20 min session Smile
[Image: 2012-08-04_10-46-54_710.jpg]
[Image: 2012-08-04_10-50-18_736.jpg]
[Image: 2012-08-04_10-50-17_109.jpg]
[Image: 2012-08-04_10-50-15_602.jpg]
[Image: 2012-08-04_10-50-13_528.jpg]
[Image: 2012-08-04_10-46-39_455.jpg]
[Image: 2012-08-04_10-45-09_822.jpg]
[Image: 2012-08-04_10-45-06_631.jpg]
[Image: 2012-08-04_10-45-02_39.jpg]
[Image: 2012-08-04_10-43-31_282.jpg]
[Image: 2012-08-04_10-43-29_729.jpg]
[Image: 2012-08-04_10-43-27_517.jpg]
[Image: 2012-08-04_10-41-47_721.jpg]
[Image: 2012-08-04_10-40-04_677.jpg]
323F Rock
28-08-2019, 12:40 AM #19
Saturday 4th August
Cheers
Lee
Nathan
28-08-2019, 06:49 AM
very nice build! It confused the hell out of me when I saw that gearbox, then remembered it's FWD Big Grin
28-08-2019, 06:49 AM #20
Views 77,537
08-02-2024, 01:53 AM
Replies 23
Views 1,683
04-01-2023, 03:30 PM
Last Post by aaron1991ellis
Replies 65
Views 5,431
21-12-2022, 09:37 AM
Last Post by jeffrosie
Replies 179
Views 15,528
17-12-2022, 10:34 AM
Last Post by phaebo
Replies 39
Views 4,353
13-12-2022, 01:00 PM
Last Post by N15_GTi
Replies 69
Views 13,518
25-11-2022, 04:48 AM
Views 802
03-09-2022, 10:44 AM
Views 3,692
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
Replies 38
Views 4,136
18-06-2022, 08:37 AM
Last Post by Lerch
Replies 1,318
Views 95,953
05-06-2022, 08:23 AM
Last Post by sarah0
