JapCarForum Cars, Cars, Cars! Project Cars Yet Another IS200 to be Turbo'd
Pages (7): 1 2 3 4 57 Next
jeffrosie
08-12-2020, 03:09 PM
Hi guys, been on here a while now looking and reading what you'll have been doing to most fave Lexus in the country.
I too want to go down the turbo route, but need help and advice as I go along.
From what I have read, 4-6psi boost is the max the stock engine can take - given the toothpick conrods.
Also no ECU needed upto for this level of boost, just a map sensor voltage clamp - the black box as sold on here by P.Lindblom.
Just need to construct a manifold - probably log type.
Get a turbo - T28 with adjustable actuator set to 5PSI
Construct turbo out pipe to mate to catback exhaust as sold by 2fast2cool2 on ebay. Exhaust already on car and sounds great.
Engine is still healthy at 95K and just had a full service. I'll do a belt change in the summer. Doesn't use any oil and still pulls well. Just had MOT so all in all - good nick.
May need a clutch, so what uprated clutch assembly do you'll use? I had read/heard that std Celica GT4/MR2 Turbo pressure plate and drive plate is a bolt on! Can anybody confirm?
Also read that Celica 1ZZFE green injectors are a direct bolt on with a very slight increase in cc? Do they help and not over fuel with just the blackbox?
Probably more questions to come Smile
Cheers Guys
jeffrosie
08-12-2020, 03:09 PM #1
Cheers Guys
08-12-2020, 11:52 PM
Hi mate. Some good starting points there.
You'll prob have to make a tubular manifold. A log is generally cast so mass produced.
Injectors do for your right. And your best going for something like the emanage ultimate to be honest.
08-12-2020, 11:52 PM #2
gsitlv
09-12-2020, 02:08 AM
few people on here running up to 9psi on stock internals, so i would say 4-6psi is safe
gsitlv
09-12-2020, 02:08 AM #3
09-12-2020, 08:48 AM
Unrelated to your car specifically, but how far would 15psi get you in terms of horse power on a 1g-fe?
A big issue of "safe" is map and heat, so if you sort cooling out, you might be able to push a bit more boost and remain in safe territory.
09-12-2020, 08:48 AM #4
09-12-2020, 10:14 AM
el_bandido Unrelated to your car specifically, but how far would 15psi get you in terms of horse power on a 1g-fe?
290-300hp at the flywheel
09-12-2020, 10:14 AM #5
john wan
09-12-2020, 10:37 AM
Good ideas bud get some pictures up. i was originally looking to make my manifold log style but in the end I got a cheap 2jz manifold an chopped the flanges off an welded 1gfe ones on , but now ive got all the bits to make a log one im going to try that when I get the time they dont win any awards for being priety but they work .
good luck with the build expect sleepless nights and a bauld patch from standing back and scratching your head ha ha ha
Edited 20-01-2014, 08:12 PM by john wan.
john wan
09-12-2020, 10:37 AM #6
jeffrosie
09-12-2020, 10:53 AM
Cheers guys for the info.
Haven't bought anything as yet, just making lists and doing research as don't want anything to go horribly wrong.
So 0.5bar/7psi should be safe.
Still need to know about clutch as I'm pretty sure my current one won't hold up.
What clutch you using John?
jeffrosie
09-12-2020, 10:53 AM #7
john wan
09-12-2020, 11:12 AM
Standard an its fine mate
john wan
09-12-2020, 11:12 AM #8
jeffrosie
09-12-2020, 11:17 AM
Ok Thanks John
Its probably the same as used as the Altezza.
The 1ZZFE Green injectors. Are they needed? or is it only when going Emanage Ultimate?
jeffrosie
09-12-2020, 11:17 AM #9
Ok Thanks John
john wan
09-12-2020, 11:28 AM
Im running standard injectors car didnt like the green ones when I fitted them I had a problem with my fuel regulator wouldnt drop low enough an was running rich
Think standard clutch is also used on tow cars so used to the strain
john wan
09-12-2020, 11:28 AM #10
Views 6,193
09-04-2024, 01:09 AM
Views 1,573
06-04-2024, 05:57 PM
Views 111,806
25-03-2024, 02:10 AM
Views 10,783
23-03-2024, 03:45 PM
Views 23,808
18-02-2024, 11:42 PM
Views 77,546
08-02-2024, 01:53 AM
Views 505
18-12-2023, 02:55 AM
Views 1,669
08-10-2023, 03:59 AM
Views 3,528
04-10-2023, 03:52 PM
Views 2,280
17-05-2023, 11:25 AM
