JapCarForum Cars, Cars, Cars! Project Cars Lexus is200 se
Lexus is200 se
Lexus is200 se
Pages (42): 1 2 3 4 542 Next
is200turbo
07-09-2020, 10:48 PM
Hi I'm looking to turbo my is 200 and looking around the web I have found a few ways to do this but which is the best for the money and has potential of more upgrades,
2jz loads of power but initial cost is really expensive round 15k
1jz same as above but just a bit cheaper
1ggte been told is almost a straight swap but does the wiring need changing? And wot else is needed to convert the car ie gearbox etc
1gfe just fit a turbo kit but pistons and rods are over 2 k so will make the conversion quite expensive
Please I need your advice the car will be a second car soon so time is not that important
Thank you in advance
Sent from my iPhone using Tapatalk - now Free
is200turbo
07-09-2020, 10:48 PM #1
08-09-2020, 12:12 AM
Its a matter of deciding how much you want to spend.
1GFE with gte or uprated pistons and a turbo you can push some good figures.
1GGTE is an easy fit but parts are extremely rare and ultimately need to be custom
2JZ is hard conversion but lots of parts available
08-09-2020, 12:12 AM #2
is200turbo
08-09-2020, 01:10 AM
Wot sort of figures could I expect with a 1g-fe with 1g-gte pistons and rods and would I need the crank from the gte?
is200turbo
08-09-2020, 01:10 AM #3
08-09-2020, 02:49 AM
depends on what GTE you get, the gen 1 has a different crank so youll need that,
the gen 2 and 3 have the same crank as the FE so you can use either.
as for power, people are running 300bhp
08-09-2020, 02:49 AM #4
is200turbo
08-09-2020, 10:21 AM
Any idea where the best place is to get some pistons and rods as I can not find any where that does them for the 1g-gte.
Will the 7m-gte pistons and rods got?
is200turbo
08-09-2020, 10:21 AM #5
mattlaw
08-09-2020, 10:36 AM
Easy an cheaper option, buy paddywaks supercharged is300
mattlaw
08-09-2020, 10:36 AM #6
08-09-2020, 10:37 AM
No 7m parts won't work
08-09-2020, 10:37 AM #7
is200turbo
08-09-2020, 10:51 AM
mmm thats not good then looks like i might have to find i different root then Confusedad:
Do the engines come up for sale very often? and wot is needed to wire the gte engine in? is it a big job
is200turbo
08-09-2020, 10:51 AM #8
08-09-2020, 11:04 AM
They are rare mate, very rare, you could import one from aus?
To wire it in you'll need a standalone ecu or some ingenious wiring to wire the Lexus and 1ggte ecus in at the same time. Can be done though. A lad I know in Barbados has done exactly that
08-09-2020, 11:04 AM #9
is200turbo
08-09-2020, 11:16 AM
cheers stav i will have to keep looking or just get the pistons and rods for the fe.
Are they still available?
is200turbo
08-09-2020, 11:16 AM #10
Views 6,065
09-04-2024, 01:09 AM
Views 1,559
06-04-2024, 05:57 PM
Views 111,746
25-03-2024, 02:10 AM
Views 10,628
23-03-2024, 03:45 PM
Views 77,354
08-02-2024, 01:53 AM
Views 501
18-12-2023, 02:55 AM
Views 1,665
08-10-2023, 03:59 AM
Views 6,974
06-10-2023, 02:58 AM
Views 3,461
04-10-2023, 03:52 PM
Replies 76
Views 3,454
30-09-2023, 01:24 AM
Last Post by RichS11
