JapCarForum Cars, Cars, Cars! Project Cars Advice wanted on turboing my is200
Alex mcginley
06-12-2023, 03:58 PM
Hello lads new to the page . I am wanting to Turbo my is200. But need few questions answered like..
Wat Turbo can I use.
We're dos oil feed and return go..
Wat bout fuel do I need to modify it or can I lave it as is.
Wat bout wiring will it need messed with.
Will my car need remaped or dyno tuned after I fit Turbo. Thanks in advice..
Alex mcginley
06-12-2023, 03:58 PM #1
Morango
07-12-2023, 09:49 AM
I have a second is200 i am looking at turboing so been through all this:
Any you want, something the small that spools up fast will be best as you wont be able to go high with the boost. Custom manifold will have to be made.
We're does oil feed and return go..
Feed is from the vvti pipes, return into sump?
Bigger injectors would be handy - can get bigger ones from rav4 or celica or something
Some sort of piggy back ecu will be required, I am going standalone as i want to remove all of the **** and get max power, its also alot easier to make work.
The piggy back or standalone will need to be remapped.
If your budget is high then go for 1jz/2jz swap. You get alot more for your money and it would be easier than turboing the 1g fe lump. But my 1jz gte vvti swap cost somewhere around £5000 - but thats 340bhp and potential for 600hp in the future and more after that.
If you turbo the 1g fe you will be lucky to get 250 - 300 before engine starts to die
Morango
07-12-2023, 09:49 AM #2
Alex mcginley
07-12-2023, 03:14 PM
Ok. Will a Turbo is a Subaru work something like td04... also Wat is a standalone and how do wire it
Alex mcginley
07-12-2023, 03:14 PM #3
08-12-2023, 12:07 PM
Yeah a Subaru turbo will work with the right manifold flanges,
A standalone is an ecu to replace the standard one mate.
08-12-2023, 12:07 PM #4
18-12-2023, 02:55 AM
have you got anywhere with doing the work yet mate
18-12-2023, 02:55 AM #5
Views 6,065
09-04-2024, 01:09 AM
Views 1,560
06-04-2024, 05:57 PM
Views 111,747
25-03-2024, 02:10 AM
Views 10,628
23-03-2024, 03:45 PM
Views 23,306
18-02-2024, 11:42 PM
Views 77,354
08-02-2024, 01:53 AM
Views 1,665
08-10-2023, 03:59 AM
Views 3,461
04-10-2023, 03:52 PM
Views 2,269
17-05-2023, 11:25 AM
Replies 83
Views 5,065
06-05-2023, 06:32 AM
Last Post by Niliano
