JapCarForum Cars, Cars, Cars! Project Cars My Lexus RS200 Turbo Build
Pages (3): 1 2 3 Next
Lexus RS200T
04-06-2022, 06:31 PM
Hi Ladies and Gents. This is my Lexus IS200 build that started July of 2010.
I bought my 3SGTE ST215W engine. It was complete with 2 broken sensors. I stripped of the intake and exhaust manifold and small bits of pieces because just going to drop the engine in like that.
In November 2010 I bought my Lexus IS200 where we were going to build the engine into.
Pearl white with full beige leather inside.
Lexus RS200T
04-06-2022, 06:31 PM #1
05-06-2022, 12:54 AM
Nice! Keep the pictures regular!
05-06-2022, 12:54 AM #2
Lexus RS200T
05-06-2022, 01:14 AM
How do I post pictures. My posting rules says "you may not post attachments"
Lexus RS200T
05-06-2022, 01:14 AM #3
05-06-2022, 10:46 AM
You need to use something like photobucket to host your photos mate.
05-06-2022, 10:46 AM #4
Lexus RS200T
06-06-2022, 05:49 PM
Here is a list of the modifications that was done from July 2010 to June 2015.
Engine.
2ltr 3S-GTE ST215 engine.
86mm 9:1 Wiseco forged pistons,
Eagle forged H-beam con-rods,
ARP 2000 conrod bolts,
ACL racing bearings,
ACL thrust washers,
1.67mm Cometic head gasket and full gasket set,
ARP head stud kit,
Oil filter relocation kit,
Setrab 9 row oil cooler,
Aero oil thermostat,
Oil catch can,
Power steering cooler,
Head gasflowed and valves reseated,
Works adjustable cam pulleys,
Stainless steel braided oil, fuel lines and anodized FTF Fittings,
FTF reusable fuel filter,
FTF Fuel pressure regulator,
Deatschwerks 320Lph fuel pump,
Delphi 1000cc injectors,
Power mods DFi EFI,
GFB boost controller,
Modified Garret T60-1 turbo,
Tail F38 38mm external wastegate,
450*300*76mm front mount intercooler,
76mm exhaust with a wastegate screamer pipe
Transmission
Toyota Altezza RS200 transmission,
Toyota Altezza RS200 flywheel,
Spec Stage 3 clutch,
Toyota Land cruiser starter motor,
Brakes
EBC turbo grooved front discs,
EBC standard rear discs,
EBC yellow stuff front brake pads,
EBC green stuff rear brake pads,
Stainless steel braided brake lines,
Suspension
KYB shocks all around,
Tein lowering kit all around
Lubrication
Liqui-Moly High Performance Gear Oil (GL 4+) SAE 75W-90,
Liqui-Moly Top Tec ATF 1100,
Liqui-Moly Brake Fluid DOT 4,
Shell Helix HX3 SAE40 oil for running in.
Audio
Reference audio Blade 12.2 500w-rms subwoofer,
Reference audio Blade 6.2 splits,
Earth Quake 600w 6x9 in the rear,
Reference audio Tivo 600w-rms monoblock,
Reference audio Blade 2400w 4 channel,
ICE 7inch double din radio
When I can upload photos I will show them.
Lexus RS200T
06-06-2022, 05:49 PM #5
Engine.
ACL thrust washers,
ARP head stud kit,
Oil catch can,
Power mods DFi EFI,
Transmission
Brakes
Suspension
Lubrication
Audio
07-06-2022, 11:06 AM
What ecu do you run on this mate?
Sounds like a sweet build.
07-06-2022, 11:06 AM #6
Lexus RS200T
07-06-2022, 06:38 PM
Powermods DFi ecu. South African produced and very good. Here is the website:
http://www.powermods.co.za
Lexus RS200T
07-06-2022, 06:38 PM #7
Lexus RS200T
08-06-2022, 07:15 PM
My Lexus when I bought it 0n 9 November 2010.
It had a small problems like the Left brake caliper was seized, there was a couple of dents on the bonnet, bumpers and rear quarter.
But what a lovely car, if you think what you get with the car and its over 15years old then you know Lexus was on the ball with this vehicle, only thing is that the 2litre engine is dead like an old mans vehicle.
.jpg
.jpg
.jpg
Lexus RS200T
08-06-2022, 07:15 PM #8
.jpg
.jpg
.jpg
Lexus RS200T
08-06-2022, 08:38 PM
On the 3 August 2010 I bought my 3SGTE ST215W engine. She wasn't a looker but had loads of potential, for what I wanted from her and that was to eat up Golf GTI, cause they where a pain in my backside.
.jpg
Lexus RS200T
08-06-2022, 08:38 PM #9
.jpg
Lexus RS200T
08-06-2022, 08:50 PM
So from the 3 August 2010 till 9 November 2010, I stripped the engine in such a manner that we just change the necessary thing like intake, exhaust manifold, turbo, Changed the pickup of the oil cause the engine in the Caldina sits at and angle and now we are going to transplant it into a Lexus IS200 for RWD sitting straight.
We stripped the intake manifold, exhaust manifold and turbo combination, alternator, power steering pump, oil sump, oil pickup, oil pump, charcoal canister and all its other useless small bits, cam cover, timing belt, power steering and alternator belts. I even left the head gasket as this was suppose to be a drop in project,
Little had I know that this project was going to finish 5 years after a bought the engine.
Lexus RS200T
08-06-2022, 08:50 PM #10
Views 111,806
25-03-2024, 02:10 AM
Views 23,808
18-02-2024, 11:42 PM
Views 77,546
08-02-2024, 01:53 AM
Views 1,185
31-10-2023, 10:05 PM
Views 1,669
08-10-2023, 03:59 AM
Views 7,105
06-10-2023, 02:58 AM
Views 3,528
04-10-2023, 03:52 PM
Replies 76
Views 3,495
30-09-2023, 01:24 AM
Last Post by RichS11
Views 23,912
10-09-2023, 07:50 PM
Views 2,280
17-05-2023, 11:25 AM
