JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Bypass cable and now lacking bass.
21-09-2019, 09:20 AM
I wonder if the 8 speaker system is presenting the wrong resistance to the stereo. That's a lot of load to put on a head unit that's only designed to run 4 speakers, but I don't know how the bypass cable works with regard to summing the loads from the speakers. I'd expect each speaker to be 4ohm and depending how the bypass cable is wired it might be connecting 4 rear cones to 2 speaker outputs, which would make them 8ohm.
I've never actually done this in a Lexus so that's about the most help I can be I think!
21-09-2019, 09:20 AM #11
Predator
21-09-2019, 09:53 AM
I was just about to check if the head unit is designed with just 4 speaker out signals.
I was concerned that by disconnecting (bypassing the amp) I may have switched off/disconnected the shelf speakers.
I'll check now.
John
Predator
21-09-2019, 09:53 AM #12
I'll check now.
John
Predator
21-09-2019, 10:07 AM
Right, I've been outside and had a listen.
I can confirm that all the speakers are working, including the tweeters.
Maybe the stock unit sounds better or maybe after 10 years I've forgotten what to expect.
Either way, I think I need to add a small sub/bass box. Nothing major, just a bit of punch.
Thanks for all your help toxo
Cheers,
John
Predator
21-09-2019, 10:07 AM #13
Cheers,
John
21-09-2019, 11:24 AM
Both sets of rear speakers may to be working, depends on your bypass cable mate. There's actually 2 speakers on top of each other in each side at the back. Without checking the wiring thou won't know if bothered working.
21-09-2019, 11:24 AM #14
Predator
21-09-2019, 12:20 PM
Sparkystav Both sets of rear speakers may to be working, depends on your bypass cable mate. There's actually 2 speakers on top of each other in each side at the back. Without checking the wiring thou won't know if bothered working.
Oh, I see. Can I use a voltmeter to check?
Cheers, mate
John
Predator
21-09-2019, 12:20 PM #15
Cheers, mate
John
21-09-2019, 02:32 PM
Yeah that would work! Easiest way is at the connection from the bypass to the Lexus plug see if all the wires are there and working. On one I installed they weren't.
21-09-2019, 02:32 PM #16
Predator
21-09-2019, 02:35 PM
Coolio, sparky. I'll get on to that, after the weekend.
I've got double exams this weekend, covering 14 topics Sad
Cheers,
John
Predator
21-09-2019, 02:35 PM #17
Cheers,
John
21-09-2019, 02:42 PM
Predator Coolio, sparky. I'll get on to that, after the weekend.
Cheers,
John
Grim!
21-09-2019, 02:42 PM #18
Cheers,
John
Grim!
Predator
21-09-2019, 02:46 PM
You summed it perfectly!
John
Predator
21-09-2019, 02:46 PM #19
John
05-10-2019, 03:19 AM
How'd you get on?
05-10-2019, 03:19 AM #20
How'd you get on?
Views 683
02-12-2020, 01:19 PM
Replies 88
Views 19,651
26-01-2020, 06:18 AM
Last Post by iceman
Views 582
26-01-2020, 01:12 AM
Last Post by Colin G
Views 2,426
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 655
02-04-2019, 08:16 AM
Last Post by James S
Views 1,043
11-02-2019, 09:50 AM
Last Post by northernmonkey
Replies 22
Views 2,701
06-11-2018, 11:29 AM
