Pages (17): Previous 1 2 3 4 517 Next
13-03-2021, 03:02 PM
Daniel N Once again thanks a lot. I now know what to get. I will just have to decide if I'm going for bigger injectors or try to see if the injection of fuel is good enough on the standart injectors with an AFR gauge.
Like Stix said though, they are not 100% necessary, it depends on how safe the AFR on your particular car is.
But either way the 1ZZ injectors will give a bit more power.
13-03-2021, 03:02 PM #11
Daniel N
13-03-2021, 03:18 PM
Okey. I'll rather be on the safer side so I'll go with the 1ZZ-FE injectors. Do you know which size belt I need for the 140mm pulley or 145mm? Haven't decided which pulley yet..
Daniel N
13-03-2021, 03:18 PM #12
JayJay1374
02-04-2021, 05:28 PM
Ste176 will have a 145mm pulley for sale soon i think mate
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
02-04-2021, 05:28 PM #13
Ste176
02-04-2021, 05:48 PM
This week in fact if everything goes to plan.
Ill be looking for £150.00 GBP deliverd first class signed for.
Cheers
Ste176
02-04-2021, 05:48 PM #14
Cheers
Daniel N
02-04-2021, 05:59 PM
Thanks guys. But I have already ordered a 145mm pulley from "Godfather" on the euro Lexus owners club.
BTW he said I should use injectors from a Toyota Celica 2ZZ-GE engine. These injectors will work for 140mm and 145mm.
Regards
Daniel
Daniel N
02-04-2021, 05:59 PM #15
Regards
Daniel
03-04-2021, 09:17 AM
Daniel N Thanks guys. But I have already ordered a 145mm pulley from "Godfather" on the euro Lexus owners club.
Regards
Daniel
In my last setup (almost 2 years) I used 2zz yellow injectors (310cc) and a 148mm pulley. The car worked fine together with the e-manage.
03-04-2021, 09:17 AM #16
Regards
Daniel
Daniel N
03-04-2021, 03:32 PM
Sounds good Dimis. Is it necessary with the e-manage. Or will my black box from Patrik be ok?
Daniel N
03-04-2021, 03:32 PM #17
03-04-2021, 03:33 PM
Daniel N Sounds good Dimis. Is it necessary with the e-manage. Or will my black box from Patrik be ok?
with the 140mm pulley and the 1zz injectors i think you will be fine, but you will gain more power with an emanage and a good map.
03-04-2021, 03:33 PM #18
Daniel N
03-04-2021, 03:41 PM
I'm going for the 145mm and 2zz-ge injectors setup. Could the black box work with this?
Daniel N
03-04-2021, 03:41 PM #19
03-04-2021, 04:24 PM
Daniel N I'm going for the 145mm and 2zz-ge injectors setup. Could the black box work with this?
Well make sure your AFR it is at the safe side. I cannot guarentee you will be safe with only the black box.
03-04-2021, 04:24 PM #20
Views 846
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 327
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 555
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 776
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 452
26-07-2022, 05:09 PM
Last Post by reganlives
Views 488
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 693
17-09-2021, 09:42 PM
Last Post by gsitlv
