JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Boost Gauge via Scanguage II
reganlives
25-06-2020, 03:20 AM
Stav, I'm going to go for a proper gauge instead, just not sure which one to go for or which pod.
reganlives
25-06-2020, 03:20 AM #11
25-06-2020, 03:42 AM
Stoney I don't think this would work. Scangauge reads data from the ECU doesn't it? And on a charged car the ECU sees a false boost signal due to the black box mod, and so the scangauge would show that figure, not true boost.
Dark Samurai Nah you'll need a boost pressure sensor wired into the ECU guys.
Sparkystav if you read boost via the OBDII with a charger it shows you what the ecu sees which is a clipped signal thanks to the black box or fcd
Thanks for clearing that up Stav. Oli, get back in your cage.
Edited 06-08-2013, 01:16 PM by Stoney.
25-06-2020, 03:42 AM #12
25-06-2020, 09:21 AM
Now now. No need to be harsh. Plus right you'll need to wire a boost sensor in. But into the scan gauge.
25-06-2020, 09:21 AM #13
25-06-2020, 10:03 AM
Defi gauges and greddy pillar pod the way to go
25-06-2020, 10:03 AM #14
25-06-2020, 10:09 AM
Moley Defi gauges and greddy pillar pod the way to go
Defi are good too. Most of the top (expensive!) brands are pretty good. If you don't wanna put a pod in the centre of the dash the greddy pillar pod the best/only way to go. Best for line of sight too.
Sparkystav Now now. No need to be harsh.
I was being fairly friendly, Oli would know if I was being harsh. Smile
Sent from my Nexus 4 using Tapatalk 2
25-06-2020, 10:09 AM #15
reganlives
25-06-2020, 10:32 AM
What if I don't want to spend a fortune? Lol
reganlives
25-06-2020, 10:32 AM #16
25-06-2020, 10:37 AM
reganlives What if I don't want to spend a fortune? Lol
Some of the cheap eBay ones can be OK, especially of slight inaccuracy is not a big deal.
25-06-2020, 10:37 AM #17
25-06-2020, 11:37 AM
Unlucky then , you will just have to use cr&p ones then lol
25-06-2020, 11:37 AM #18
 3 Guest(s)
 3 Guest(s)
Views 1,646
05-07-2023, 05:08 AM
Last Post by damtrx
Views 405
21-12-2022, 02:57 AM
Last Post by lexusdaydreaming
Views 306
21-03-2021, 07:12 AM
Views 244
28-01-2021, 10:29 AM
Views 423
03-12-2020, 09:38 AM
Views 255
28-04-2020, 01:27 PM
Views 246
07-03-2020, 12:49 PM
Views 696
30-06-2019, 11:49 AM
Views 609
04-09-2018, 02:44 AM
Last Post by P.Lindblom
