JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission JUN flywheel. Which clutch?
Daniel N
27-06-2020, 08:03 AM
Ok Stav. Thanks for your feedback.
Daniel N
27-06-2020, 08:03 AM #11
marko45
14-07-2020, 11:11 PM
I also plan to buy a JUN lightweight flywheel and I had the same question in mind: which clutch? I read that the 1GFE clucth is not compatible because the JUN flywheel is a solid mass and the OEM flywheel is a dual mass. Is it true ? Does the 1ggte clutch kit is compatible with the supercharger kit?
marko45
14-07-2020, 11:11 PM #12
marko45
19-08-2020, 09:30 PM
Sparkystav Disc: 31250-22220
Cover: 31210-22050
Are these the only two parts i need to buy if i want to install a 1ggte clutch kit on my is200?
marko45
19-08-2020, 09:30 PM #13
Cover: 31210-22050
19-08-2020, 10:11 PM
you need a solid flywheel
19-08-2020, 10:11 PM #14
marko45
20-08-2020, 01:11 AM
Sparkystav you need a solid flywheel
Yes of course. I will buy a Jun flywheel but i do not want a stage 1 clutch.
marko45
20-08-2020, 01:11 AM #15
philip_98
20-08-2020, 03:32 AM
http://www.ebay.co.uk/itm/LEXUS-IS200-2-...0732347109
Will that clutch work with the JUN flywheel?
philip_98
20-08-2020, 03:32 AM #16
20-08-2020, 04:38 AM
yep
20-08-2020, 04:38 AM #17
yep
marko45
20-08-2020, 08:13 AM
marko45 Are these the only two parts i need to buy if i want to install a 1ggte clutch kit on my is200?
The bearing is included in one these references or there is no need to change it and just keep the bearing of the 1gfe ?
marko45
20-08-2020, 08:13 AM #18
20-08-2020, 08:52 AM
why don't you fit an aftermaket clutch-plate?Since you are fitting a solid flywheel OEM or aftermarket will do the same job. Aftermarket even better.
20-08-2020, 08:52 AM #19
Views 975
22-06-2023, 12:14 AM
Last Post by XeDoX
Views 214
30-08-2020, 12:09 AM
Views 335
08-04-2018, 08:49 AM
Last Post by spud1973
Replies 29
Views 1,522
10-09-2017, 07:50 AM
Views 618
10-05-2017, 05:11 PM
Last Post by Asi
Views 643
25-10-2016, 12:11 PM
Views 504
02-10-2016, 11:25 AM
Last Post by wahidhussain
Views 388
12-07-2016, 04:15 AM
Last Post by Asi
Views 812
26-05-2016, 01:55 AM
Last Post by edeath
