JapCarForum Cars, Cars, Cars! Project Cars Rd legal drag Supra build - Project Zoran
Marco79
19-09-2021, 12:45 PM
After a bunch of problems finally got all the welding, exhaust fabricating done Big Grin
EGT bung welded on and in the background the custom pipe I've made to connect the wastegate to the downpipe Big Grin
[Image: null_zpsc9d5f85e.jpg]
Will get more pics of the rest in a day or two but now all that's done the manifold can be wrapped and final fitted Big Grin
Marco79
19-09-2021, 12:45 PM #11
Marco79
19-09-2021, 12:47 PM
Bit more of an update my downpipe was originally matched to a different manifold which had the wastegate going straight to the downpipe, my new manifold had the wastegate 180degrees out! Instead of cutting the manifold I cut the flange off the downpipe, blanked the hole off and rewelded the flange in the right place
[Image: null_zps87059631.jpg]
[Image: null_zpsa0f7a8ab.jpg]
I then fabricated a pipe to connect the wastegate
[Image: null_zps021a3ea8.jpg]
[Image: null_zpsf51f33de.jpg]
[Image: null_zpsb5c654d4.jpg]
[Image: null_zps7b1fedb2.jpg]
Now all this was done I've started the wrapping mission Smile 50ft of wrap later.......
[Image: null_zps4366ae07.jpg]
Just ordered the 2" wide wrap to finish the manifold off and do the downpipe Smile
Marco79
19-09-2021, 12:47 PM #12
Marco79
19-09-2021, 12:49 PM
Had a good hit today, I trimmed, positioned and welded up the backbox and after a fair bit of playing I'm finally happy with it Big Grin
[Image: IMG_2777_zps8eaab5f9.jpg]
[Image: IMG_2778_zpsada19f23.jpg]
[Image: IMG_2771_zpsccfc25e4.jpg]
[Image: IMG_2776_zps897a3d38.jpg]
[Image: IMG_2774_zpse9805bec.jpg]
[Image: IMG_2773_zpsc9f1a8b0.jpg]
Marco79
19-09-2021, 12:49 PM #13
Marco79
19-09-2021, 12:50 PM
Finished wrapping the manifold now Big Grin
[Image: null_zpsaea9d3d0.jpg]
[Image: null_zps609b4b33.jpg]
[Image: null_zps28adbd6b.jpg]
Just the downpipe left now Smile
Marco79
19-09-2021, 12:50 PM #14
Marco79
19-09-2021, 12:51 PM
Final fitted the manifold, turbo, wastegate and downpipe (ran out of wrap for the last bit Sad ) also fitted the AFR and EGT sensor
[Image: null_zps44e8061c.jpg]
Also fitted the mirror polished water pump pulley cover Big Grin
[Image: null_zps8d45dd5f.jpg]
And my polished starter motor Big Grin
[Image: null_zps8a73ff51.jpg]
Next stop is to fit the engine Big Grin
Marco79
19-09-2021, 12:51 PM #15
Marco79
19-09-2021, 12:53 PM
Well it was a bit of a wrestle but the engine is finally in Big Grin
[Image: null_zpsd6179659.jpg]
[Image: null_zps101d3a07.jpg]
[Image: null_zps4393288a.jpg]
Now the turbo elbow is touching near the strut has anyone ideas on how much clearance is needed? The engine will rok so don't really want it too hit
[Image: null_zps7938be90.jpg]
[Image: null_zps050e19a8.jpg]
Also has anyone got pictures of a front shot of theirs without rad etc so I can compare the engine angle as without a gearbox on there is quite a variable angle that the engine sits and this effects where the turbo sits Wink
[Image: null_zps156809b3.jpg]
Marco79
19-09-2021, 12:53 PM #16
Marco79
19-09-2021, 12:54 PM
Fitted the -12 breather system and radiator ( can anyone tell me if there is supposed to be any kind of rubber mount on the lower radiator mount feet?)
[Image: null_zpsafbdbed7.jpg]
Also started plumbing in the fuel lines -12 feed to the pump with 100micron filter and shutoff valve then -10 from pump to bulkhead where it splits to twin -8 feeds to the fuel rail with a -6 return
[Image: null_zps7ef753a5.jpg]
Marco79
19-09-2021, 12:54 PM #17
Marco79
Fitted most of the fuel system now with it all P clipped in place and the -6 return line to FPR fitted Smile just the twin -8 rail feeds needed now once I've sourced the fuel rail Smile
[Image: null_zps8a63c0eb.jpg]
[Image: null_zpsf5911b03.jpg]
[Image: null_zpse410429d.jpg]
[Image: null_zps2fe42f30.jpg]
Marco79
19-09-2021, 12:54 PM #18
19-09-2021, 01:06 PM
thats going to be sweet as once its back together good work, what ffim is that your using? i want an ffim at one point in the future Smile
Edited 31-10-2013, 04:53 PM by is300_dino.
19-09-2021, 01:06 PM #19
Marco79
19-09-2021, 01:11 PM
is300_dino thats going to be sweet as once its back together good work, what ffim is that your using? i want an ffim at one point in the future Smile
Thanks mate the ffim is this one Big Grin
http://www.suprastore.com/2jinmabywope.html
Marco79
19-09-2021, 01:11 PM #20
Views 5,140
04-04-2025, 09:14 PM
Last Post by DannyStock
Replies 257
Views 42,163
02-01-2025, 02:13 PM
Views 3,493
Views 4,037
Views 14,289
Views 6,987
Views 2,804
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 35,127
Replies 79
Views 11,387
02-09-2024, 04:19 PM
Views 1,544
21-05-2024, 04:24 AM
