JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission IS200 Wont start/Bad misfire
jonesy200
19-01-2021, 10:21 AM
Ok so iv taken the cams off set the bottom crank to the second notch and refitted cams to tdc etc but now its hitting the valves ie iv rotated manualy. What am I doing wrong??
jonesy200
19-01-2021, 10:21 AM #11
19-01-2021, 12:28 PM
Something sounds very wrong that's for certain, it certainly shouldn't be hitting. I'd recheck your work, then check the pulley on the cams hasn't slipped on the cam maybe?
19-01-2021, 12:28 PM #12
jonesy200
19-01-2021, 10:30 PM
The pulley on the cam only goes on 1 way as it has a pin on the cam to line it up on. Am i right in saying if i remove the cams all the valves will spring back thus ableing me to rotate the bottom crank freely which is what iv done? I put a rod in num 1 spark whole and the bottom piston is at its top when the bottom crank is lined up which is right, right??
jonesy200
19-01-2021, 10:30 PM #13
20-01-2021, 03:58 AM
Depends on which stroke it's on. There should be a mark on the cam pully to show tdc
20-01-2021, 03:58 AM #14
jonesy200
20-01-2021, 04:15 AM
[Image: 44qdd9e03]
jonesy200
20-01-2021, 04:15 AM #15
[Image: 44qdd9e03]
jonesy200
20-01-2021, 04:20 AM
[IMG][Image: 2014_02_27_16_08_04.jpg][/IMG]
jonesy200
20-01-2021, 04:20 AM #16
jonesy200
20-01-2021, 04:21 AM
[Image: 2014_01_26_13_00_27.jpg]
jonesy200
20-01-2021, 04:21 AM #17
jonesy200
20-01-2021, 04:23 AM
jonesy200 [IMG][Image: 2014_02_27_16_08_04.jpg][/IMG]
After rebuild
jonesy200
20-01-2021, 04:23 AM #18
After rebuild
jonesy200
20-01-2021, 04:24 AM
jonesy200 [Image: 2014_01_26_13_00_27.jpg]
Before Rebuild all lined up.
jonesy200
20-01-2021, 04:24 AM #19
jonesy200
20-01-2021, 04:51 AM
Ok so iv found something. Iv been lining the cam pulley up with the indentation on the pulley and not the small mark so how will i adjust this without[Image: cam.png] valves hitting etc?
jonesy200
20-01-2021, 04:51 AM #20
Views 313
09-01-2023, 02:08 PM
Last Post by Hoseer
Views 298
10-02-2022, 04:05 PM
Views 303
15-01-2022, 02:19 AM
Views 613
18-10-2021, 01:45 AM
Views 250
27-04-2021, 11:43 PM
Views 173
12-05-2020, 03:26 AM
Last Post by Ji123
Views 230
15-01-2020, 09:55 AM
Last Post by Jon
Replies 18
Views 893
13-12-2019, 10:14 PM
