JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Projector Headlights for IS200?
iLLzLex
18-08-2016, 02:05 AM
steviewevie Put HIDs in your headlamps , they'll be what you're using most of the time, and it's illegal to drive round with your fog lights on when there's no fog. By all means go for the fogs as well to complete the look though.
Have a look at the Ace Cafe if you like, to see the difference between headlamp HIDs and halogens.
You can also put main beam HIDs in too, some people (e.g. Wozza) have that, though I don't.
Yeah I think that should do... erm and I'll get those rings too, I think I'll have to get someone to fit it thought...cause when I fitted them on my last car the wires were everywhere and it made it look untidy...not good at keeping things tidy under the hood...
iLLzLex
18-08-2016, 02:05 AM #11
18-08-2016, 02:07 AM
If you want projector headlights there is a company in the US called AAC who do it - it's not cheap though.......
18-08-2016, 02:07 AM #12
18-08-2016, 02:09 AM
HIDs are very very easy to fit. Usually on the IS200 though, you have to connect things up with reversed polarity (e.g. install the connectors between HID ballast and bulb back-to-front) for some reason to make it work. Basically you can try it the "normal" way and if that doesn't work, simply reverse the connection (just un-plug and re-plug, not talking about anything complicated here).
18-08-2016, 02:09 AM #13
iLLzLex
18-08-2016, 02:12 AM
parthiban If you want projector headlights there is a company in the US called AAC who do it - it's not cheap though.......
You're a star...I particularly like these as well...
http://www.automotivelightstore.com/inde...ProdID=449
:drool:
iLLzLex
18-08-2016, 02:12 AM #14
:drool:
18-08-2016, 02:14 AM
If you want to fit something like that in the rear lights, you need to carefully cut them open with something like a Dremel, and then re-seal them when done.
18-08-2016, 02:14 AM #15
iLLzLex
18-08-2016, 02:17 AM
steviewevie HIDs are very very easy to fit. Usually on the IS200 though, you have to connect things up with reversed polarity (e.g. install the connectors between HID ballast and bulb back-to-front) for some reason to make it work. Basically you can try it the "normal" way and if that doesn't work, simply reverse the connection (just un-plug and re-plug, not talking about anything complicated here).
Yeah I know they are extremely easy to fit...but it's all the hiding the wires and placing of the balasts...I'd prefer it to look OEM...but knowing me and my clumsyness at DIY it would be wires caught up in the timing belt:cursing:
iLLzLex
18-08-2016, 02:17 AM #16
18-08-2016, 02:19 AM
It's easy on the passenger side, there's loads of room for a ballast and you can tidy away the wires with a cable tie.
On the driver's side there's a lot less room, but you can still squeeze in a ballast and similarly just use cable ties to keep things relatively tidy.
18-08-2016, 02:19 AM #17
iLLzLex
18-08-2016, 02:22 AM
Just ordered the 6K H.I.Ds!!! (with super slim ballast) ...
Hopefully will have them by Ace Cafe meet...erm also got the LED sidelight bulbs...and as regarding to the halo rings I will wire them up to the sidelight but also to a relay and to a remote control to use as a strobe for when the car is parked at meets Wink Jeeez...you guys are making me think up of ideas...I'm buying you a beer at Ace stevie Tongue
iLLzLex
18-08-2016, 02:22 AM #18
18-08-2016, 02:23 AM
iLLzLex You're a star...I particularly like these as well...
:drool:
Yep AAC do some pretty nice stuff, spoke to them a while back but when you factor in the shipping and all that it was looking like a lot of money - plus you'd be without headlights for a while so would need to source some spares to use in the meantime or keep the car off the road.
Although if you were interested (as I was) they can't do the gattling gun projectors for RHD, they said they use normal BMW projectors for RHD cars.
18-08-2016, 02:23 AM #19
:drool:
iLLzLex
18-08-2016, 02:46 AM
parthiban Yep AAC do some pretty nice stuff, spoke to them a while back but when you factor in the shipping and all that it was looking like a lot of money - plus you'd be without headlights for a while so would need to source some spares to use in the meantime or keep the car off the road.
It's a shame theres no UK based company that does this...maybe it's a niche?
iLLzLex
18-08-2016, 02:46 AM #20
Views 325
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 1,076
28-05-2023, 02:46 PM
Last Post by bigdave1701
Replies 47
Views 3,561
08-12-2022, 09:37 AM
Views 346
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 971
23-03-2021, 07:29 AM
Last Post by kaykay
Views 421
15-09-2020, 02:23 PM
Replies 31
Views 2,185
25-07-2020, 07:50 AM
Replies 22
Views 1,454
09-07-2020, 04:04 PM
Last Post by powerdbyis
Replies 103
Views 6,724
31-03-2020, 07:02 AM
Last Post by Barry
