JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza fitting a hks FCD- a guide or directions??
09-09-2016, 05:37 AM
If yours did have the black box attached at some point, you should be able to see which wires were used the last time on the ecu?
09-09-2016, 05:37 AM #11
Joff
09-09-2016, 05:40 AM
and the other two i just join in????
Joff
09-09-2016, 05:40 AM #12
09-09-2016, 05:43 AM
Yes mate sorry, just trim back a bit of the wire covering and solder them into the existing wiring and wrap in insulating tape Smile
09-09-2016, 05:43 AM #13
Joff
09-09-2016, 05:48 AM
right think ive worked it out!, gona go get the soldering iron on the go,
wish me luck!
if im not back within a few mins somethings gone wrong lol!
Joff
09-09-2016, 05:48 AM #14
wish me luck!
09-09-2016, 05:51 AM
Ok mate good luck :thumbup1:
I'll be here for a bit if i can help Big Grin
09-09-2016, 05:51 AM #15
09-09-2016, 06:18 AM
its been 25min is it alive ?
09-09-2016, 06:18 AM #16
Joff
09-09-2016, 07:02 AM
no, cnt find my solder lol! waiting for my cousin to finish work and bring his around!
will let you all know the outcome!
Joff
09-09-2016, 07:02 AM #17
09-09-2016, 07:05 AM
Cool mate let us know how you get on Big Grin
Just found that i had mine set to number 9 on the dial too, and it seemed to work fine:thumbup1:
09-09-2016, 07:05 AM #18
09-09-2016, 08:16 AM
Marsdendean cant you just use connector blocks to see if it works?? Or is that a bad idea?
Bad idea!
09-09-2016, 08:16 AM #19
Bad idea!
Joff
10-09-2016, 08:20 AM
right ive put it on! and it does seem better but im unsure weater ecu is still in 'safe' mode,
the light is still on! any ideas if it will go out or how to get it out of 'safe' mode!
what level is best to have fcd set to???
Joff
10-09-2016, 08:20 AM #20
 4 Guest(s)
 4 Guest(s)
Views 446
25-06-2021, 08:14 AM
Views 204
01-07-2020, 04:42 AM
Views 664
09-01-2019, 12:06 PM
Last Post by S
Views 388
05-11-2018, 01:33 PM
Last Post by Jimbob-T-Lex
Views 749
13-07-2018, 01:11 PM
Last Post by Phil01
