JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE SC pipework size???
rob
14-11-2016, 10:22 AM
Yes but has not been delivered yet and i am on limited time in the UK so i want to order everything now and take it all back with me.
sorry 4 all the questions but the issue with the reducers made me wonder
rob
14-11-2016, 10:22 AM #11
14-11-2016, 01:34 PM
I see where you're coming from Rob, wish I could help further but I don't have an SC kit, and although I do have one of the same sort of intercoolers as Dimis, it's up at Charlesworth Motors getting the turbo conversion done at the moment.
14-11-2016, 01:34 PM #12
rob
15-11-2016, 06:34 AM
i had some info back from dimitris, he used a 63mm-57mm reducer to fit the original pipe work. based on that info i wont have any probs getting 60mm hose fitting the cooler.
rob
15-11-2016, 06:34 AM #13
15-11-2016, 08:02 AM
rob i had some info back from dimitris, he used a 63mm-57mm reducer to fit the original pipe work. based on that info i wont have any probs getting 60mm hose fitting the cooler.
Sounds good Rob :biggrin:
15-11-2016, 08:02 AM #14
rob
21-11-2016, 07:22 AM
for future infos, you do not need any reducers for the larger sized intercooler, the inlets are not 100% round but slightly oval with 66mm at the widest point, 60mm silicone hose with a 5mm wall thickness easily fits over the inlets.
rob
21-11-2016, 07:22 AM #15
rob
24-11-2016, 07:18 AM
sorry to bring this up again........ so i ordered some 50mm hose and then whilst looking for a new air filter i came across the TTE parts list and it says the bypass tube is 38mm! anyone wish to confirm?
failing that i am back with my car on the 8th and i will update.
ill be a bit pissed if i have to order another length of hose!
rob
24-11-2016, 07:18 AM #16
24-11-2016, 07:32 AM
Like Gord says his sizes are correct.
What size of clamps you going for Rob ??
24-11-2016, 07:32 AM #17
rob
24-11-2016, 08:02 AM
ok thanks for confirmation... its a right pain in the **** not being able to check on the car myself, hence all the questions!!! sorry guys.
for clamps well im not sure yet, i want to go for the mikalor type clamps but the adjustment range is so small ill have a look when i am back home and order then, but at the monent it looks like i would have to go for the 63-68mm clamps. ill also see what i can borrow :lol: from work though!
rob
24-11-2016, 08:02 AM #18
24-11-2016, 08:12 AM
rob ok thanks for confirmation... its a right pain in the **** not being able to check on the car myself, hence all the questions!!! sorry guys.
The 59- 63 clamps are more than big enough for the 60mm hoses , thats what I have used. I've not done the 50mm hoses yet so not quite sure what size you need for them but think its 53mm ones
24-11-2016, 08:12 AM #19
rob
24-11-2016, 08:48 AM
Gord You know we always willing to help Rob :thumbup: unlike the dickhead on the other side giving members wrong info, i look just for the fun now :thumbup: :lol:
ta gord... not sure who the dickhead is, but ill find out in soon course tho.
rob
24-11-2016, 08:48 AM #20
Views 354
16-09-2020, 08:38 AM
Last Post by philip_98
Views 742
18-09-2019, 10:35 AM
Views 511
17-12-2018, 10:18 AM
Last Post by S
