JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Aftermarket Headunit - Fitting
18-01-2017, 05:20 AM
I used the metal oem ones on mine mate found them a better fit,
I ran my cables down the passenger side under the door sills and up the side of the rear seat, through the hole near the top of the back seat, And its good practice to run power cables one side and the rca's down the other? helps to keep any interference down from the power cables etc? :thumbup1:
18-01-2017, 05:20 AM #11
18-01-2017, 06:40 AM
Bandit I used the metal oem ones on mine mate found them a better fit,
That good advice there Bandit
18-01-2017, 06:40 AM #12
18-01-2017, 08:18 AM
Good stuff, was hoping that I would be able to use it as it seems more secure, yeah will run the cables seperatly, done that in the last car, although I can't remember which side I run the AI net cable, think I sent it with the power leads!
18-01-2017, 08:18 AM #13
18-01-2017, 08:41 AM
We installed a sub in my dad's boot, and ran the power and RCA cables down the passenger side, amd there has been/is no interference.
18-01-2017, 08:41 AM #14
21-01-2017, 05:01 AM
ok got another question, obviously i will want to be able to use the dvd player on the move, what do i need to do with the brake cables from the head unit loom, just earth it?
Edited 04-03-2010, 02:59 PM by SHAHZ.
21-01-2017, 05:01 AM #15
21-01-2017, 06:10 AM
Yes, just connect it to earth. Underneath the gear surround there are some bolts which go into the chassis, which you can use for that purpose.
21-01-2017, 06:10 AM #16
21-01-2017, 07:16 AM
steviewevie Yes, just connect it to earth. Underneath the gear surround there are some bolts which go into the chassis, which you can use for that purpose.
Is the same for both brake wires on alpine units?
21-01-2017, 07:16 AM #17
21-01-2017, 07:20 AM
SHAHZ Is the same for both brake wires on alpine units?
I don't know Alpine units specifically, but what do the instructions say, does it say both wires have to be connected to the brake, to earth ? Normally they're connected to the handbrake circuit, and that's earthed when the handbrake is on, so connecting them to any handy earth will do the trick.
21-01-2017, 07:20 AM #18
21-01-2017, 11:17 PM
Ok ignore my last comment I looked last night and there is only 1 wire......my excuse was it was late when I was looking at it and I had dust in my eyes from sanding the facia:Fish:Big Grin::pBlush
21-01-2017, 11:17 PM #19
TM
21-01-2017, 11:22 PM
ConfusedcaredBig GrinVD ,phones,are the same as drink drives........danger:Chair:
i've seen it all before......just take care......:blink:
TM
21-01-2017, 11:22 PM #20
Views 796
31-03-2020, 12:49 PM
Replies 88
Views 19,645
26-01-2020, 06:18 AM
Last Post by iceman
Views 708
28-09-2019, 08:22 AM
Views 331
04-09-2019, 11:50 PM
Views 910
29-04-2019, 07:48 AM
Views 817
26-12-2018, 07:50 AM
Views 394
06-11-2018, 01:05 PM
Last Post by yellowbob
Views 601
04-05-2018, 12:42 PM
