JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lack of power
Lack of power
Lack of power
01-04-2017, 09:53 AM
The fuel filter is in the fuel tank. I don't think Lexus normally do anything with it. I don't think the fuel filter is normally replaced in their service schedule either, in this country, because our petrol is normally very clean (unlike in some countries).
To clean the K&N filter you can give it a bit of a brush-off/vacuum - but make sure you are sucking the dirty stuff out of the side where it has gathered, not pulling it all the way through the filter. For a proper clean you can buy proper K&N recharging kits from eBay - it gives you some cleaning stuff to spray on, then you wash the filter off and leave it to try. Then you re-oil it using the oil from the kit.
01-04-2017, 09:53 AM #11
Marsdendean you get a servicing kit for them, but i forgot you was running a k&n filter!! My Leon was running like rubbish until i changed the filter
Only thing is when my air filter was causing me trouble I had no power across the range and more at the top end.
Seeing as this is intermittent and very on-off in nature, coupled with the idling problems make me think it might be something else?
01-04-2017, 09:53 AM #12
01-04-2017, 09:54 AM
Yeah I would have thought if it was a fuel blockage or a filter blockage you'd get problems across the range, not very specifically like you're describing. No harm in checking the filter though - you never know, if you clean it a bit it might help the old fuel economy !
01-04-2017, 09:54 AM #13
01-04-2017, 10:21 AM
steviewevie Yeah I would have thought if it was a fuel blockage or a filter blockage you'd get problems across the range, not very specifically like you're describing. No harm in checking the filter though - you never know, if you clean it a bit it might help the old fuel economy !
Yep I'll give it a clean but I'll have to get the car booked in - still haven't sorted the business with the hubs so hope it's not another expensive repair on the cards........
My mpg is actually pretty good now, I'm averaging 25mpg and I've had it as high as 28 which I'm really pleased with in this car around London :thumbup:
01-04-2017, 10:21 AM #14
01-04-2017, 10:26 AM
Gord Steve my mate has sorted one or two with the same problem that you are getting, i will be seeing him tomorrow so will ask him :biggrin:
Ahh that would be awesome, would be good to know what it might be, cheers mate :thumbup:
01-04-2017, 10:26 AM #15
Andy-R.
01-04-2017, 10:27 AM
Hope it's not mate but wouldn't a failing coil pack cause thisHuh when did you last change the sparkplugs?
[Image: Lf9Nl.jpg]
Andy-R.
01-04-2017, 10:27 AM #16
[Image: Lf9Nl.jpg]
01-04-2017, 10:31 AM
Andy-R. Hope it's not mate but wouldn't a failing coil pack cause thisHuh when did you last change the sparkplugs?
According to my invoices they were replaced in Aug 2008 when I had the cambelt service done.
I'm not sure what a coil pack is but is it expensive?
01-04-2017, 10:31 AM #17
Andy-R.
01-04-2017, 10:37 AM
Plugs should be ok then mate unless you have done a million miles since then, the coil packs basically what sits over the plug like the old ht leads you get on older cars, there's one on ebay for £15 at the moment so not too expensive it's finding out which one of the 6 is at fault, but I wouldn't worry mate i'm usually way off on stuff like this.
[Image: Lf9Nl.jpg]
Andy-R.
01-04-2017, 10:37 AM #18
[Image: Lf9Nl.jpg]
spikes
01-04-2017, 11:12 AM
when you take your air filter out there is a sensor at the front of the box, give this a clean :biggrin:
spikes
spikes
01-04-2017, 11:12 AM #19
spikes
Phil01
01-04-2017, 11:14 AM
ISC, idle speed control valve??
Phil01
01-04-2017, 11:14 AM #20
Views 295
06-01-2020, 07:01 PM
Replies 25
Views 1,128
14-03-2019, 01:04 PM
Last Post by is300_dino
Replies 23
Views 1,336
29-01-2019, 03:11 PM
Last Post by jomo
Views 375
07-09-2018, 11:53 AM
Views 610
18-01-2018, 04:06 AM
Last Post by LEX11S
Views 977
25-10-2017, 08:18 AM
Last Post by reganlives
Replies 26
Views 1,158
04-10-2017, 12:10 PM
Views 360
28-02-2017, 09:59 AM
Last Post by ibby
Views 410
26-01-2017, 10:08 AM
Replies 24
Views 1,041
07-06-2016, 07:06 AM
Last Post by russelllinn
