JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Loss of Power
Loss of Power
Loss of Power
Pages (3): 1 2 3 Next
russelllinn
02-06-2017, 05:11 PM
Hi all,
Any Ideas?
When I am in fourth and fifth gear I seem to have a loss of power at 4.5k revs, they seem to die off then it it pulls again, like a blip in power momentarily!
I have had two suggestions
1 - the engine doesn't like the K&N Typhoon I have fitted.
2 - the spark plugs.
Anyone else any thoughts or knowledge
Cheers
russelllinn
02-06-2017, 05:11 PM #1
Hi all,
Any Ideas?
Cheers
aido
02-06-2017, 05:15 PM
Did you reset the ECU after fitting the induction kit?
If it's still doing it I'd swap back to the standard airbox and see what happens then?
aido
02-06-2017, 05:15 PM #2
Saraj
02-06-2017, 05:17 PM
i assume theres plenty of petrol? i only ask as i had the problem when i hardly any petrol left
Saraj
02-06-2017, 05:17 PM #3
Your right it maybe the plugs as well if there not been changed they may need changing.
What mileage and when were they last changed?
02-06-2017, 05:17 PM #4
02-06-2017, 05:30 PM
Could it be an issue with the MAF sensor ? This is an IS300, isn't it, and IS300s (unlike IS200s) have MAF sensors.
As Aido suggests, it would be worth taking off the induction kit and seeing if the problem goes away.
02-06-2017, 05:30 PM #5
russelllinn
02-06-2017, 07:16 PM
Thanks for your replies guys,
Not sure when the spark plugs were last done it does have full Lexus histoy to date and it's now on 97k!?!
It does have a MAF sensor maybe have that looked at.
Think I'll try the old air box back on it first as I can't remember if it did it when I had original one on and let you know, only thing air box is in Portsmouth at mo :tongue_smilie: (have to wait a couple of weeks)
Russ
russelllinn
02-06-2017, 07:16 PM #6
Russ
aaronabbott
02-06-2017, 07:17 PM
do u loose power or is the clutch starting to slip
aaronabbott
02-06-2017, 07:17 PM #7
Fozzy
02-06-2017, 07:28 PM
To be honest if the clutch was slipping it would be more likely to go in the lower gears than 4th or 5th
I would hazard at MAF. Does the engine note change or is there any sign of misfire when it happens?
Fozzy
02-06-2017, 07:28 PM #8
03-06-2017, 03:52 AM
It's an IS300 guys, so it's an auto Wink
03-06-2017, 03:52 AM #9
russelllinn
03-06-2017, 04:13 AM
Hi,
I don't think it's a misfire, it makes the noise of loss of power like a surge if that makes sense, as it's revving nicely then drops?
It is an auto, however I know what gears it's in as using it on the padddle shifts in manual mode!
russelllinn
03-06-2017, 04:13 AM #10
Hi,
Views 576
06-01-2021, 12:50 AM
Replies 25
Views 1,898
13-03-2020, 06:53 PM
Last Post by is300_dino
Replies 23
Views 2,320
29-01-2020, 09:00 PM
Last Post by jomo
Views 879
18-01-2019, 09:54 AM
Last Post by LEX11S
Views 1,610
25-10-2018, 02:07 PM
Last Post by reganlives
Replies 26
Views 2,344
04-10-2018, 05:59 PM
Replies 44
Views 4,279
20-04-2018, 08:57 AM
Views 547
28-02-2018, 03:48 PM
Last Post by ibby
Views 576
26-01-2018, 03:57 PM
Views 3,377
21-05-2017, 12:17 PM
