JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Fog light replacement
29-06-2017, 04:45 AM
Thanks mate, I'm guessing it'll be pretty straight forward once the arch liner's off? Job for the weekend I think Smile
29-06-2017, 04:45 AM #11
29-06-2017, 04:57 AM
Yes mate its pretty easy to do, i usually use a small ratchet spanner from the front to undo the bolts and then push them out from behind :thumbup1:
29-06-2017, 04:57 AM #12
29-06-2017, 05:00 AM
Bandit Not sure mate, the only thing that usually happens is that the bulb holder ring corrodes, which makes the bulb go very loose? apart from the bulb and wiring connector that's pretty much all the bits that can go wrong on the front fogs?
spot on mate, they are more prone to corroding on the autos cause of the vents in the arch liner..........i changed mine years ago when it corroded for the jdm black ones.....IIRC the problem is that the bulb wont come out
29-06-2017, 05:00 AM #13
29-06-2017, 05:07 AM
Oh and remember that there are 2 types of connection for the fogs when you are buying replacements from ebay, at a guess i think they changed then 2003 onwards.....i had to cut the connecters of mine and solder the new ones on!
29-06-2017, 05:07 AM #14
29-06-2017, 05:22 AM
there were new ones on ebay for 40 pounds
29-06-2017, 05:22 AM #15
29-06-2017, 05:27 AM
also there are black ones on ebay motors usa
29-06-2017, 05:27 AM #16
29-06-2017, 05:32 AM
Here we go.....
Revised fog light with plastic cap covering bulb to prevent corrosion and new connectors
[IMG][Image: Fog1.jpg][/IMG]
[IMG][Image: Fog2.jpg][/IMG]
29-06-2017, 05:32 AM #17
Here we go.....
29-06-2017, 05:43 AM
Cheers Shahz, so the bulb is likely to have corroded within the fog light housing, and that's why the whole lot needs to be replaced?
Cool, I'll try to make sure to get the same as what I've got so it's all plug and play Smile
29-06-2017, 05:43 AM #18
29-06-2017, 05:55 AM
parthiban Cheers Shahz, so the bulb is likely to have corroded within the fog light housing, and that's why the whole lot needs to be replaced?
From what i remember mate thats the case, either that or it was a case of the unit falling apart when bulb was removed, but it was over 5 years ago now so cant remember exactly what happened.
You'll need to unclip the inner arch and pull it forward (obviously with the wheel on full lock) to remove it and there are a few bolts on the front you undo with a socket through the gap next to the light:thumbup1:
29-06-2017, 05:55 AM #19
29-06-2017, 06:12 AM
SHAHZ From what i remember mate thats the case, either that or it was a case of the unit falling apart when bulb was removed, but it was over 5 years ago now so cant remember exactly what happened.
Thanks mate, sounds simple enough, I'm sure you'll hear from me if I get stuck :laugh:
29-06-2017, 06:12 AM #20
Views 518
25-06-2021, 08:14 AM
Views 300
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 546
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 312
16-09-2020, 08:21 AM
Views 372
30-07-2020, 12:35 AM
Last Post by Dinho
Views 242
11-07-2020, 01:53 AM
Views 230
01-07-2020, 12:35 AM
Views 324
28-03-2020, 10:39 PM
Last Post by James S
Views 510
10-03-2020, 11:17 AM
Views 303
10-03-2020, 08:16 AM
Last Post by Colin G
