JapCarForum General Discussions The JCF Lounge Used car advice
Used car advice
Used car advice
21-07-2017, 04:49 AM
Initially:
Any "bad" records in a VIN history report?
Any maintenance records, mileage proof?
How many previous owners?
Why do they sell a car - tired of fixing it?
Any accidents, engine, transmission repair?
Has the car passed last Emission Test?
Start with exterior.
Indications of possible problem:
Are the exterior lines not straight? Ripples? Misaligned panels?
Driver's door has free play in the hinges? Troubles to close?
Are the gaps between panels too narrow (too wide) on one side of the car?
Lots of rusty spots?
Mismatched colors? Painting over spray?
Any panel of the car seems to be repainted?
Why? Accident? Corrosion?
Trailer hinge? The car was using for towing?
Indications of possible engine problem:
Any oil or coolant leaks from the engine?
Is the engine dirty or oily?
Is the oil level low? Is the oil on the dipstick too dark?
Any indication of poor quality repair work / lack of maintenance? (e.g. badly corroded battery terminals, very low oil level, etc.)
Start the engine:
Does it work unevenly?
Any knocking, pinging, whistling?
Any smoke? (slight water steam is OK)
Any warning lights come on while the engine is running?
"Check engine" light?
Is the engine oil pressure too low at idle?
Any hesitation on acceleration?
Is the engine enough powerful?
Does it look very dirty under the oil cap?
Smell of the burnt oil under the hood?
Possible automatic transmission problems:
Any previous transmission repair? Was it rebuilt?
Does the transmission fluid smell burnt?
Is the tranny fluid on the dipstick too dark/dirty?
Start the engine and try to switch from P to D and from P to R holding the brakes -
Is the time between shifting and the moment the transmission kicks in too long?
Any strong noises or jerks?
During a test drive:
Any delays or troubles shifting?
Any shudder? Does the transmission slip or **** harshly?
The shifting seems to be delayed?
Does the kick-down function work?
The manual transmission:
Any leaks?
Any noises while driving?
Any troubles changing gears?
Is the clutch slipping?
Any trouble to shift into reverse?
The suspension problems:
Is any of shock absorbers leaking?
Is any of the shock absorber boots broken?
The steering has notable free play?
Does the car bounces too much when you push one of the corners down?
Tires have irregular wear? (alignment problem)
Does the car sit level?
During a driving test:
Any knocking or creaking noises when driving over bumps?
Does the car pull aside? Is the steering wheel out of center?
Does the vehicle feel unstable on a freeway?
Any humming or growling noise?
The brakes. Possible problem:
Is the brake fluid container leaky?
Is the brake fluid level too low?
Brake pedal goes down to the floor? Break pedal is too soft (spongy)? Too hard? Any brake fluid leaks under the car?
Badly corroded brake lines? Brake rotors appear corroded? During the test drive.
Any brake pedal or steering pulsation while braking?
Does the vehicle pull aside while braking?
Any grinding noise?
Does the brake warning light or ABS light come on while driving?
Tires:
Any cracks, bruises?
Tread appears low?
Mismatched tires?
Damaged rims?
Vibration at high speed?
Humming noise? (uneven tire wear?)
The interior:
Is the driver seat / steering wheel worn excessively?
Dampness under the carpet or in the trunk?
Does the Radio / CD / Tape work?
Has the odometer any evidences of being tampered?
Does the air conditioner provide really cold air?
Are the power locks, windows, mirrors, sunroof, etc. working?
Are the heater, rear window defogger working?
Wind noise while driving?
Any of warning lights come on while driving?
Do you feel comfortable in driver's place?
Seats, seat belts, mirrors, controls, steering, visibility?
Spare tire, jack, wheel wrench?
21-07-2017, 04:49 AM #11
Initially:
Start the engine:
Any leaks?
Any grinding noise?
Tires:
Tread appears low?
Mismatched tires?
Damaged rims?
The interior:
21-07-2017, 05:11 AM
blimey .. remind me not to sell a car to you without having a week spare for the questionnaires, form filling etc lol...
21-07-2017, 05:11 AM #12
21-07-2017, 05:18 AM
lol only someting I nicked from somewhere on the 'net.
21-07-2017, 05:18 AM #13
21-07-2017, 05:36 AM
Cheers that's a brilliant list :thumbup:
Now just to learn it so I remember what to check :laugh:
21-07-2017, 05:36 AM #14
21-07-2017, 05:42 AM
Phil someone has far to much time on their hands to make a list like that and to think he or she has missed a few off:lol:
21-07-2017, 05:42 AM #15
21-07-2017, 05:59 AM
[COLOR="Indigo"]
Couldn't resist, had to have a go at this lol.. sorry
Any "bad" records in a VIN history report? yes, it was bad in 1996 but it was young... it's been on the norty step and it's fine now
Any maintenance records, mileage proof? flolders of them, all in order Smile yay pass Smile
How many previous owners? a few, it was too fast for them
Why do they sell a car - tired of fixing it? Sell it ? sell it? are you mad, you'll have to shoot me for it.
Any accidents, engine, transmission repair? do you count spilling my nailvarnish on the old floor mats ?
Has the car passed last Emission Test? lol.. would I be driving it if it hadn't Smile
Are the exterior lines not straight? Ripples? Misaligned panels? one or two bits of kit aren't quite flush but when you get to it's age you'll have a few bits like that too boyo!
Driver's door has free play in the hinges? Troubles to close? her doors shut perfectly, phew another pass
Are the gaps between panels too narrow (too wide) on one side of the car? for what ? what exactly are you going to try sticking between her panels ? maybe this questionnaire should be how responsible a buyer you are !
Lots of rusty spots? its orange paint, not rust ejiit.. sheesh you will be saying the other one is gunmetal grey next :p
Mismatched colors? Painting over spray? it goes white under orange streetlights ... but its supposed to ok!
Any panel of the car seems to be repainted? they've all been repainted, at the same time.. the receipt is in the folder
Why? Accident? Corrosion? to make it orange silly
Trailer hinge? The car was using for towing? no! and dont you dare try it .. its a sports car not a landrover!
Any oil or coolant leaks from the engine? none at all.. but the pipes., well.. erm .. oh you didnt ask Smile pass Smile
Is the engine dirty or oily? no room for dirt under my bonnet
Is the oil level low? Is the oil on the dipstick too dark? nope, perfectly full, perfectly coloured.. changed last friday :p
Any indication of poor quality repair work / lack of maintenance? (e.g. badly corroded battery terminals, very low oil level, etc.) lack of maintenance? have you seeeeeen the number of folders I have on the car.
Start the engine:
Does it work unevenly? nope its female not male !
Any knocking, pinging, whistling? it sucks and spits ( and it's supposed to), if you hear anything else turn the stereo up
Any smoke? (slight water steam is OK) smoke no, no smoking zone .. steam no, defeats the object of straightening my hair every morning !
Any warning lights come on while the engine is running? not since i took the bulbs out no Smile
"Check engine" light? where's that then? I have checked there is one, when you put the bonnet up its all that 'stuff' underneath
Is the engine oil pressure too low at idle? you stick your finger in there and see
Any hesitation on acceleration? lolololololol dont know much about 3.0 supras do ya
Is the engine enough powerful? lolololololol... how much g-force is not enough for you
Does it look very dirty under the oil cap? I Mr Sheened it this morning
Smell of the burnt oil under the hood? nope, cooked the odd mouse in the exhaust pipe but not under the bonnet, no
Any previous transmission repair? Was it rebuilt? does it look like lego to you
Does the transmission fluid smell burnt? I told you, no cooking under my bonnet.. dont care what you want to use
Is the tranny fluid on the dipstick too dark/dirty? there is no way I can answer this with a straight face !
Start the engine and try to switch from P to D and from P to R holding the brakes -if you don't hold the brakes make sure theres plenty of space and no people stood infront/behind the car !
Is the time between shifting and the moment the transmission kicks in too long? why? haven't you put your seatbelt and shades on yet ?
Any strong noises or jerks? erm... excluding the buyer ? sorry Smile just kidding Smile
Any delays or troubles shifting? not for you cos you WONT be driving it Smile
Any shudder? Does the transmission slip or **** harshly? it doesnt use four star, v power only or she will evict you !
The shifting seems to be delayed? erm... it goes vrooooooooom, change, vroooooooom, change .. you want less o's or what ?
Does the kick-down function work? kick my car you die .. oh you mean .. heck yeah it works, you just have to decide which level of facelift you want .. gentle smoothing, cheeks in your ears or or full on so taught you can tie a knot at the back of head with what used to be your eyebrows
The manual transmission: havent got this so I can skip to next section? phew .. there's a week saved
Any leaks?
Is any of shock absorbers leaking? erm... there's no puddles under the car or in the undertrays so I guess not
Is any of the shock absorber boots broken? no way, they're Jimmy Choo's :p
The steering has notable free play? besides round to the left and round to the right you mean :p that's free
Does the car bounces too much when you push one of the corners down? no but if you push too hard you'll break the splitter and she will be really really mad at you !
Tires have irregular wear? (alignment problem) not yet, they're new
Does the car sit level? unless you park it on a slope, then it has trouble being level :p
Any knocking or creaking noises when driving over bumps? nope.. the splitter wont go over bumps so that eliminates that problem Smile
Does the car pull aside? Is the steering wheel out of center? the steering wheel is on the left idiot not in the centre .. thats the stereo volume !
Does the vehicle feel unstable on a freeway? erm.. who is driving ?
Any humming or growling noise? only a passenger, turn the stereo up if it annoys you
Is the brake fluid container leaky? you're obsessed with leaks .. the car is not incontinent !
Is the brake fluid level too low? nope, its perfect
Brake pedal goes down to the floor? Break pedal is too soft (spongy)? Too hard? Any brake fluid leaks under the car? unless the mat is tucked up under it .. then its a bit scary
Badly corroded brake lines? Brake rotors appear corroded? if you're two inches thin, feel free to go check Smile
Any brake pedal or steering pulsation while braking? its a car not one of those toys !
Does the vehicle pull aside while braking? only if the police tell you to
Any grinding noise? passengers teeth .. turn stereo up if it bothers you
Does the brake warning light or ABS light come on while driving? wouldnt know, if i have to brake that hard i am too busy trying to work out which will be the least damaging thing to hit .. oh it might be one of the bulbs i took out .. they're all different colours, its annoying
Tires:
Any cracks, bruises? the tyres are black, you wont see a bruise
Tread appears low? its on the ground, how low are you not expecting it to be !
Mismatched tires? all black, colou co-ordinated perfectly
Damaged rims? maybe if i hit your head against them Smile
Vibration at high speed? you run alongside and see :p
Humming noise? (uneven tire wear?) you run alongside and listen :p .. if there is, turn the stereo up
The interior:
Is the driver seat / steering wheel worn excessively? I tend to wear clothes personally, its not ideal to go to work wearing a steering wheel
Dampness under the carpet or in the trunk? trunk? it's a supra not an elephant
Does the Radio / CD / Tape work? heck yeah, we've turned it up times so far havent we !
Has the odometer any evidences of being tampered? it gets polished once a week
Does the air conditioner provide really cold air? are you paying the petrol bill to try it ?
Are the power locks, windows, mirrors, sunroof, etc. working? everything except the sunroof.. it hasnt got one
Are the heater, rear window defogger working? heater yes, defogger maybe needs attention, it was still a bit foggy outside when I got to work yesterday
Wind noise while driving? eject the passenger ! or close the window, dopey
Any of warning lights come on while driving? didn't you read about the bulbs above or was that so long ago you forgot
Do you feel comfortable in driver's place? not if you want to live longer than the next ten seconds
Seats, seat belts, mirrors, controls, steering, visibility? yes I have all them, now get outta my car
Spare tire, jack, wheel wrench? wrapped round your neck soon if ya don't get lost !
Don't think I better sell my car in the near future lol [/COLOR]
21-07-2017, 05:59 AM #16
[COLOR="Indigo"]
Start the engine:
Any leaks?
Tires:
The interior:
21-07-2017, 06:15 AM
FFS now who has to much time on their hands:Chair:
21-07-2017, 06:15 AM #17
21-07-2017, 06:18 AM
lol.. it was fun Smile and my coffee was too hot, so it was a long coffee break Smile
21-07-2017, 06:18 AM #18
21-07-2017, 06:32 AM
:laugh:
If you do ever come to sell it though, I'd be afraid for anyone who tries asking any awkward questions :tongue_smilie:
21-07-2017, 06:32 AM #19
:laugh:
21-07-2017, 06:33 AM
purplewitch lol.. it was fun Smile and my coffee was too hot, so it was a long coffee break Smile
lol, gunmetal greyRolleyes
21-07-2017, 06:33 AM #20
Replies 36
Views 865
07-07-2020, 12:01 PM
Views 219
08-03-2020, 11:01 PM
Last Post by Multics
Replies 47
Views 1,748
13-03-2019, 09:59 PM
Replies 25
Views 950
08-03-2019, 11:00 AM
Views 265
19-01-2019, 10:45 AM
Last Post by Stoney
Views 422
01-09-2018, 08:50 AM
Last Post by mr2tubbyben
Views 224
10-08-2018, 02:20 PM
Last Post by Saraj
Views 1,314
30-06-2018, 02:32 PM
Last Post by Dark Samurai
Replies 58
Views 2,180
25-05-2018, 10:36 AM
Last Post by Saraj
