JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Fitting IS300 exhaust on an IS200
09-12-2017, 01:59 AM
this info was taken from Bahmute cars
09-12-2017, 01:59 AM #11
09-12-2017, 02:03 AM
internet can be a dangerous place if you dont do research properly always check, check again, double check then post save appearing foolish with responses.
im not saying im always correct i could still be wrong in what i have found but i do hope not Ormi can you confirm the location of the sensors so we can get this back on track
to put this topic back on track
from what i understand i would need to use an O2 Simulator in order to save drilling holes in the exhaust...
Stav can you confirm then we can edit this thread and stick it with the relevant details
09-12-2017, 02:03 AM #12
09-12-2017, 04:28 AM
An O2 sim would/should do the trick andy, then just use a bung in the hole where the original sensor would go, and should work a treat Smile dont forget you would need to use another cap type bung in the floor where the cabling would go or you could end up with a wet carpet
09-12-2017, 04:28 AM #13
09-12-2017, 05:04 AM
Hmmmm, would it not be far easier to do a swap (£'s either way) with Phil01 and yourself Rabster, he is buying an IS200 'zorst that won't work without modding - from Demon, and you have an IS300 'zorst that also won't fit without modding.....................
Clearly depends on which 'zorst you have Rabster???????
09-12-2017, 05:04 AM #14
09-12-2017, 05:17 AM
Nooooo Phil, we want our Hiper, and it's ours ;D
09-12-2017, 05:17 AM #15
09-12-2017, 05:51 AM
That sounds sensible mate but Oli clearly wants extra hastle lol.
All I need is a simulator then and no holes to block up as there are no holes as the Is300 it's located pre cat so mine is all good
Sounds like Oli and phil will have fun though lol
09-12-2017, 05:51 AM #16
09-12-2017, 06:00 AM
Rabster That sounds sensible mate but Oli clearly wants extra hastle lol.
I think so.
09-12-2017, 06:00 AM #17
I think so.
Phil01
09-12-2017, 06:05 AM
b2 s2 on a 300 is under the car, approx under front drivers seat, not in the down pipes
Phil01
09-12-2017, 06:05 AM #18
Phil01
09-12-2017, 06:09 AM
the hiper we our getting is only cat back so no sensors, no welding and no sims to worry about.
Phil01
09-12-2017, 06:09 AM #19
09-12-2017, 06:39 AM
There will be phil as the is200 sensor is post cat thus u will have a hole in it sorry mate
09-12-2017, 06:39 AM #20
Views 319
13-12-2023, 02:06 PM
Views 464
09-11-2023, 03:46 AM
Last Post by Dinho
Views 678
06-11-2022, 01:49 AM
Views 1,099
02-11-2022, 10:55 AM
Views 301
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,108
23-02-2022, 01:20 PM
Views 345
18-10-2021, 02:04 AM
Views 446
03-09-2021, 11:04 AM
Views 482
29-08-2021, 09:59 AM
Replies 35
Views 7,689
04-08-2021, 04:34 AM
Last Post by cjoseph
