JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Grille connections
Grille connections
Grille connections
Ally
11-05-2018, 06:14 AM
jimxms If you do happen to measure them, can you post the sizes (pwetty plz). I need to get some too, but after ordering the wrong ones I spat the dummy and used zip ties :p
It'll probably be the weekend now, but i'll post the sizes up Smile
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
11-05-2018, 06:14 AM #11
Ally
18-05-2018, 01:03 AM
Measured the clip. 18mm wide, 20mm high, to fit a 8mm hole. I reckon these are the closest fit :- http://cgi.ebay.co.uk/Toyota-Push-Rivet-...3caacface4
Ally
18-05-2018, 01:03 AM #12
18-05-2018, 01:49 AM
Awesome mate! I just looked back at the ones I purchased and they were for a 10mm hole and didn't fit. So those ones look to be on point.
18-05-2018, 01:49 AM #13
Ally
18-05-2018, 02:27 AM
I think i might just swing past B&Q on the way home from work and get some 8mm shiney bolts Smile
Ally
18-05-2018, 02:27 AM #14
18-05-2018, 02:36 AM
Just be aware that the push-pins that go into the holes that are part of the headlights are near impossible to access from behind and get a nut on. Hence the reason for needing these.
I had the same idea with some shiny red annodised bolts, but it didn't pan out too well.
Edited 29-06-2011, 12:11 PM by jimxms.
18-05-2018, 02:36 AM #15
Ally
23-05-2018, 01:15 AM
Ally Measured the clip. 18mm wide, 20mm high, to fit a 8mm hole. I reckon these are the closest fit :- http://cgi.ebay.co.uk/Toyota-Push-Rivet-...3caacface4
Ordered these ones in the end and they arrived on Saturday. Glad to say they are a perfect fit. They are actually better than the original ones, as they are a push pull fit rather than the plastic screw type that gets chewed up with the screwdriver. I got a bag of 20 so i'll bring a few to JAE if anyone wants to upgrade :wink:
Ally
23-05-2018, 01:15 AM #16
23-05-2018, 03:39 PM
Cheers fella, been meaning to measure mine for ages, just ordered me some too!
23-05-2018, 03:39 PM #17
Views 275
18-12-2021, 09:53 AM
Last Post by Matt_C
Views 575
25-02-2020, 03:56 AM
Views 534
05-08-2019, 08:34 AM
Last Post by PETEHAMASAKI
Views 888
09-09-2016, 04:20 AM
