JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Is the UniChip a realistic upgrade?
26-05-2018, 12:19 PM
toxo Dunno if 2bar do unichips but Ryan is based in this area.
Emailed Ryan earlier, his reply was basically...They don't do piggybacks for the IS200, and said tbh he would go full standalone or leave it as it is. And said unless you've already done lots of other performance mods the standalone would be pointless anyway.
So I'm just going to leave it untill I've got a few other bits done because at the moment any sort of chip would be pretty ineffective anyway.
26-05-2018, 12:19 PM #11
26-05-2018, 12:26 PM
mine will still be for sale , if you need it
26-05-2018, 12:26 PM #12
26-05-2018, 12:29 PM
I keep thinking I should buy it just because it's so cheap! But then I'm thinking that money could be going towards the mods I need first aaaahhhhhh.
26-05-2018, 12:29 PM #13
26-05-2018, 12:30 PM
So to clarify.... Mark @ TDI tried to sell you a Unichip, telling you all the great things it would do. A handful of members warn about his advice. Then an expert is said chips says they don't make one for your car and if they did it would be pointless?
Essentially a remap makes sure all the other mods are working together optimally, so the more modified the engine, the more benefit you will get, and also see the biggest gains are always on boosted cars. Also, technically, you should remap after any major upgrade to ensure the optimal performance.
26-05-2018, 12:30 PM #14
26-05-2018, 12:36 PM
Stoney So to clarify.... Mark @ TDI tried to sell you a Unichip, telling you all the great things it would do. A handful of members warn about his advice. Then an expert is said chips says they don't make one for your car and if they did it would be pointless?
I still think what Mark said was correct, as the UniChip does work, and it can perform the function of a CamCon so should get good results. Ryan at 2bar never said it wouldn't work, just that they don't do piggybacks for the IS200.
And yes I agree with your second point about the remap being more effective the more mods you have.
26-05-2018, 12:36 PM #15
26-05-2018, 12:38 PM
It was on my car when I bought it , and we only took it off when we fitted the supercharger , just because we could not remap it there and then .
Its on ebay at the moment .........
http://cgi.ebay.co.uk/dastek-unichip-Lex...45fba1a893
26-05-2018, 12:38 PM #16
26-05-2018, 12:40 PM
Moley It was on my car when I bought it , and we only took it off when we fitted the supercharger , just because we could not remap it there and then .
So would it be safe to use the chip in its current state on any other IS200 then? For example, I buy it an use it with its current map untill I get a few other mods and then get a proper map after?
I just don't wanna do anything that will screw up my engine.
26-05-2018, 12:40 PM #17
26-05-2018, 12:47 PM
Well my car just had an induction kit and a blueflame exhaust fitted for the map thats on it .
but I cant say this would be good enough for your car or not . I'm not going to be responsible for saying yes or no
26-05-2018, 12:47 PM #18
27-05-2018, 12:47 AM
Question is, does the IS200 ECU undo any changes that a piggyback makes?
I know that with the IS300 you need to reset the ECU every few weeks if you are running a piggy back, because the ECU looks at the fuel trims and notices that they aren't what it considers to be normal so makes adjustments that effectively undo the tune on the piggy.
27-05-2018, 12:47 AM #19
27-05-2018, 01:06 AM
That's an interesting one, I'd heard that was the reason you can't remap the stock ecu, as it just teaches itself the old settings. Not really thought about it with piggybacks though, hmmm.
27-05-2018, 01:06 AM #20
Replies 31
Views 2,291
24-07-2019, 02:42 PM
Last Post by sprinter2012
Views 864
17-02-2019, 07:52 AM
Last Post by Jon
Views 734
13-07-2017, 06:09 AM
Last Post by Dan_Turism0
Views 1,146
28-05-2016, 10:47 AM
