JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Does my speedo need to be fitted to change the milage?
30-05-2018, 12:09 PM
So thats 3 converters I need now? lol
As much as I love the look of it, I'm beginning to think its not worth chopping up 3 sets of wires, because I might want to change it back at some point.
Any idea about why the ABS light is staying on? :confused:
30-05-2018, 12:09 PM #11
30-05-2018, 12:10 PM
just been thinking about it and it needs to convert the signal by about 0.6 give or take.
you could just use a speedo kmh/mph convertor as all that does is convert the signal by 0.6 as well (ration between km and miles)
30-05-2018, 12:10 PM #12
30-05-2018, 12:11 PM
sprinter2012 So thats 3 converters I need now? lol
3 converters?
one for speed, one for revs, and what else?
30-05-2018, 12:11 PM #13
3 converters?
30-05-2018, 12:12 PM
One for the odometer? Or is that something they can change electronically?
30-05-2018, 12:12 PM #14
30-05-2018, 12:14 PM
no the odometer will be changed with the same as the speedo mate, as it takes it signal from the same wire
30-05-2018, 12:14 PM #15
30-05-2018, 12:16 PM
aah okay then, and one final thing. If i decided to just leave the revs as they were, is it going to screw up the motor making it move that fast?
30-05-2018, 12:16 PM #16
30-05-2018, 12:18 PM
no mate, its what its designed for, but a speedo converter on the rev signal should work.
30-05-2018, 12:18 PM #17
30-05-2018, 12:21 PM
Okay thats good to know, I was just considering leaving the revs as they were...I quite like seeing the needle go flying over to 10,000 rpm on a late change :wink:
30-05-2018, 12:21 PM #18
30-05-2018, 01:14 PM
mine does that and i have left it alone, not sure if it's the wrong thing to do
30-05-2018, 01:14 PM #19
30-05-2018, 06:47 PM
well stav said the motors can cope fine, and unless you need your rpm dial to be accurate for race changes or something, I don't see any problem with it showing a bit higher than it should.
30-05-2018, 06:47 PM #20
Views 520
25-12-2020, 03:27 AM
Last Post by gsitlv
Views 587
20-08-2019, 04:01 AM
Last Post by S
Views 454
22-03-2019, 11:34 PM
Last Post by reco2k
Views 866
31-01-2019, 02:46 AM
Replies 25
Views 1,439
28-10-2018, 09:56 AM
Last Post by davidjamesbattersby
Views 433
12-08-2018, 10:12 AM
Last Post by jimxms
Views 362
20-07-2018, 01:40 AM
Last Post by Fozzy
Views 429
03-06-2018, 02:28 PM
Last Post by Kerja
