JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Has anyone got is300 lights fitted to their is200
19-07-2018, 05:41 AM
I was wondering, why you guy want to change for IS300 lights? With modifications to bodywork and brackets and things, as well as looms and HID connectors etc. Why not just de-tango the standard IS200 units and fit HIDs? Seems a simpler solution that would give the same result, unless I have missed something?
19-07-2018, 05:41 AM #11
speedfreek
19-07-2018, 05:48 AM
Stoney I was wondering, why you guy want to change for IS300 lights? With modifications to bodywork and brackets and things, as well as looms and HID connectors etc. Why not just de-tango the standard IS200 units and fit HIDs? Seems a simpler solution that would give the same result, unless I have missed something?
Where's the fun in that! Smile
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
19-07-2018, 05:48 AM #12
[/SIZE]
(Current project)
19-07-2018, 06:12 AM
speedfreek Where's the fun in that! Smile
Baking the lights in the oven to open them to de-tango might be fun?
Where is the fun is going to a lot of effort to retro fit lights that don't fit properly, and yet look no different?
19-07-2018, 06:12 AM #13
19-07-2018, 06:19 AM
You should do your home work matey...no need for loom changes you just buy an adapter...the inside of the light is diff..I already have detangoed and painted the lights...after a few mods they do fit correctly...
Also because they are standard hid the beam pattern is better than the 200 lights..
19-07-2018, 06:19 AM #14
19-07-2018, 06:55 AM
ormi You should do your home work matey...no need for loom changes you just buy an adapter...the inside of the light is diff..I already have detangoed and painted the lights...after a few mods they do fit correctly...
Only quoting what I read above. If the beam pattern is different, then that is a viable reason I suppose, but I had not heard that mentioned before.
19-07-2018, 06:55 AM #15
19-07-2018, 08:30 AM
also im sick of mine steaming up....lol
19-07-2018, 08:30 AM #16
Phil01
19-07-2018, 11:36 PM
The correct beam pattern with a perfect cut off and no light scatter is worth the work on its own ormi, simple job and all you need is the loom to fit the D2R bulbs,
http://www.ebay.co.uk/itm/PAIR-D2S-D2R-S..._500wt_922
Edited 31-08-2011, 09:10 AM by Phil01.
Phil01
19-07-2018, 11:36 PM #17
Fry-Up
22-07-2018, 12:14 AM
Ormi have you tried unplugging the side light bulb when drivin with headlights on to evapoate any fluid from inside the lenses? It worked on mine
Fry-Up
22-07-2018, 12:14 AM #18
22-07-2018, 01:55 AM
Fry-Up Ormi have you tried unplugging the side light bulb when drivin with headlights on to evapoate any fluid from inside the lenses? It worked on mine
That should get rid of any moisture in there. But if they are leaking, then it will get back in. Baking in the oven too warm up the adhesive and then firmly resetting the edges should solve it for good.
But I think Ormi is now at the stage Stav was at a while ago, his car is so modded, he is now just looking for anything else he can mod! :lol:
22-07-2018, 01:55 AM #19
22-07-2018, 02:32 AM
just buy a new set from the usa like i did, much better and solves the problem Smile
22-07-2018, 02:32 AM #20
Views 413
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 913
06-11-2022, 01:49 AM
Views 3,043
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,593
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
Replies 35
Views 8,064
04-08-2021, 04:34 AM
Last Post by cjoseph
