JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Throttle body
Throttle body
Throttle body
13-07-2018, 03:14 AM
Great info mate.
13-07-2018, 03:14 AM #11
Great info mate.
13-07-2018, 03:18 AM
There could be yet more complication but I can't remember if IS200s are fly-by-wire or not.
13-07-2018, 03:18 AM #12
13-07-2018, 03:20 AM
toxo There could be yet more complication but I can't remember if IS200s are fly-by-wire or not.
I believe they are.
13-07-2018, 03:20 AM #13
I believe they are.
15-07-2018, 10:27 AM
toxo PCV passes oil vapour back into the intake. This can gum up the IACV (idle air control valve) which is what lets a small amount of air past the throttlebody to allow the engine to idle. That's quite common.
They might've recalibrated & cleaned your TPS as well (throttle position sensor). This is the black lump that sits on the end of the shaft through the middle. It tells the ECU how open the throttle is (i.e. how flat to the floor your foot is) and also has a switch in it that engages when the throttle is shut, to tell the ECU that it should be idling.
I wonder if maybe this could be related to my 'Car sometimes wont start first time' problem HERE
I've got some seafoam fuel treatment/injector cleaner stuff so I'll spray a bit down the throttle body and see if it helps.
15-07-2018, 10:27 AM #14
16-07-2018, 12:04 AM
Good info there Toxo.
Could be, worth having it cleaned, can't believe the difference in my car before and after.
And yep £65 was money well spent as I didn't have a clue, plus it was at least half an hours work? So didn't seem too expensive, especially at dealer rates.
16-07-2018, 12:04 AM #15
Talisker
17-07-2018, 08:59 AM
The IS200 is a bit of old school fly-by-cable and fly-by-wire. The throttle cable moves a cam on the throttle body then the ECU decides what it can do and servos move the butterfly valve.
I think that's right :blink:
Talisker
17-07-2018, 08:59 AM #16
17-07-2018, 11:45 PM
Talisker The IS200 is a bit of old school fly-by-cable and fly-by-wire. The throttle cable moves a cam on the throttle body then the ECU decides what it can do and servos move the butterfly valve.
Sounds plausible. The MKIV LS400 is the same.
17-07-2018, 11:45 PM #17
19-07-2018, 12:47 AM
If the IS200 throttle cable is anything like the IS300 one, it's well worth checking that there's no slack in the cable where it meets the throttle body. There's a couple of bolts you can use to adjust it in much the same way as the brakes on a bicycle.
I tightened up mine yesterday as it was quite saggy, and the difference in throttle response is massive.
Edited 30-08-2011, 10:24 AM by jimxms.
19-07-2018, 12:47 AM #18
19-07-2018, 12:50 AM
jimxms If the IS200 throttle cable is anything like the IS300 one, it's well worth checking that there's no slack in the cable where it meets the throttle body. The's a couple of bolts you can use to adjust it in much the same way as the brakes on a bicycle.
I think that's true of all cars :lol: Certainly nearly every one that I've worked on has had slack in the throttle cable, and it does make a big difference.
19-07-2018, 12:50 AM #19
19-07-2018, 12:53 AM
toxo I think that's true of all cars :lol: Certainly nearly every one that I've worked on has had slack in the throttle cable, and it does make a big difference.
Lol yeah, though I've only ever worked on the IS300 as my previous ride was a push bike :p
I also fixed a load of other f*kups i made on my car last night and the car drives 1000x better now, but that's a story for another thread.
19-07-2018, 12:53 AM #20
 6 Guest(s)
 6 Guest(s)
Views 636
07-06-2019, 02:01 AM
Last Post by S
Views 389
22-12-2018, 01:54 AM
Last Post by Talisker
Views 436
06-12-2018, 11:25 PM
Last Post by P.Lindblom
Views 873
12-09-2018, 04:29 AM
Last Post by jimxms
Views 422
27-04-2018, 01:31 AM
Last Post by is300_dino
Replies 61
Views 3,449
17-01-2018, 04:49 AM
Last Post by jimxms
Views 423
10-10-2017, 08:57 AM
Views 239
09-10-2017, 05:41 AM
Views 483
30-07-2017, 01:30 AM
Last Post by Hogan22a
