JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Front Fog Lights
Front Fog Lights
Front Fog Lights
27-11-2019, 08:28 AM
ormi they did change the bulbs older ones used hb4 then they changed them
the newer ones ran h3's
Yeap and the later ones also had a plastic cap behind the bulb to prevent them from corroding. I cut the wires and soldered and covered with heat shrink when I replaced mine.
27-11-2019, 08:28 AM #11
27-11-2019, 10:53 AM
2tongues Correct me if I am wrong, I think Landrovers have a breather hole + rubber tube on the top of their fog lights do they not? This would allow the water that does get in through the seals to escape in the form of steam through the rubber hose as the lamp heats up the unwanted water???
Would this be a viable option to solve the IS200's fogs misting up?
Now you mention it I think the newer ones do have a breather tube to allow moisture to evaporate.
But half the problem was the salt water splashing up in winter would corrode the aluminium from the outside, so breather tubes and plastic caps won't help that.
27-11-2019, 10:53 AM #12
27-11-2019, 11:15 AM
sprinter2012 plastic caps won't help that.
Surely a plastic cap covering the back of the fog light would help?
27-11-2019, 11:15 AM #13
27-11-2019, 07:54 PM
the foglights have a little vent with a purple mesh on for the steam to escape
27-11-2019, 07:54 PM #14
27-11-2019, 07:56 PM
Here you can see them:
[Image: IMG_1361.jpg]
27-11-2019, 07:56 PM #15
LEXOB
27-11-2019, 08:49 PM
Has anyone got a picture of the protective plastic cap on the back? I don't seem to have that! Would explain why I have to keep replacing them.
LEXOB
27-11-2019, 08:49 PM #16
27-11-2019, 11:15 PM
LEXOB Has anyone got a picture of the protective plastic cap on the back? I don't seem to have that! Would explain why I have to keep replacing them.
I may have one somewhere, will have a look for ya tomorrow
27-11-2019, 11:15 PM #17
28-11-2019, 04:34 AM
It's only the post 2003 ones that have the cap, the early ones don't.
28-11-2019, 04:34 AM #18
LEXOB
28-11-2019, 08:09 AM
Nice one Shahz. I've just got a new set of fogs and I really don't want the same thing to be happening! Otherwise i'm gonna be tempted to do a fog light delete!!!😁
LEXOB
28-11-2019, 08:09 AM #19
LEXOB
28-11-2019, 03:26 PM
parthiban It's only the post 2003 ones that have the cap, the early ones don't.
Ahh ok that explains it then. And the cap obviously won't fit the pre 2003 fogs as they revised them.
I'll try and get hold of a set of post 2003 fogs (dark) and get them fitted.
Thanks for all the replies, this forum is really active. Some of the others you can wait days for a response if at all!
LEXOB
28-11-2019, 03:26 PM #20
Views 346
07-10-2021, 07:35 AM
Last Post by Stoney
Views 386
01-07-2021, 10:30 AM
Views 1,012
01-08-2020, 02:28 PM
Last Post by jasons
Views 407
27-07-2020, 10:46 AM
Last Post by Matt_C
Views 447
18-07-2020, 06:37 PM
Last Post by Chris0121
Views 1,328
31-03-2020, 09:51 AM
Last Post by lookatmybiceps
Views 564
15-01-2020, 11:04 AM
Last Post by avi_444
