Pages (76): Previous 121 22 23 24 2576 Next
20-10-2016, 03:51 AM
New alternator belt fitted Saturday morning, Toyota very kindly got me one in for 09:30 Sat when I ordered it around 4pm Fri. Of course they are different on imports so I couldn't just grab one from Halfords :cursing:
Going back to Toyota tomorrow to pick up some bits and pieces. I think my ECU water temp sensor is on the way out, so the car struggles when its cold as it isn't aware that it needs to alter the map. So I've got one of those + gasket coming and some trim that I can modify to mount my heated seat switches. Changing the temp sensor will require a coolant bleed too... oh yeah just remembered I can't get to it without moving the chargecooler core out of the way either!! That will be fun & games, at least I can attach my HT leads container thing down onto the head and stop it rattling.
Discovered when doing alt belt that aircon belt was on the way out too so ordered one of those. I'm going to get another alternator belt too, as I don't want to get stranded again. Will be a useful spare to have for my trips to Europe etc.
I decided to wire in some LEDs on the switches so that it'll be obvious if they're accidentally left on. That's unlikely to happen on the driver's side but I can see myself driving around for days with the passenger side one on. So 2 2-colour LEDs (green for setting 1, red for setting 2), LED clip mounts and 4 resistors later that's all done. Gonna get the loom into the car hopefully at lunchtime, and I'll drill the holes and get the switches mounted on Thursday. Haven't got the seats in at the moment as I have dropped the rails off with a friend to get them welded, but should hopefully have it all fitted for the weekend. About time too, it's getting seriously cold!
Edited 01-12-2009, 01:34 PM by toxo.
20-10-2016, 03:51 AM #221
20-10-2016, 03:58 AM
I would but I broke my digital camera at a gig last week Sad
20-10-2016, 03:58 AM #222
20-10-2016, 04:05 AM
Here's that pesky list again...
  • Amp board & subs reinstalled DONE
  • Speaker wire repair for driver's door components DONE
  • Alarm siren & engine bay switch working DONE
  • Alarm total closure DONE
  • HKS CAMP installed DONE
  • Omori 45mm boost gauge fitted in-dash DONE
  • HKS SSQV fitted DONE
  • Accessory Fuse & Relay box installed DONE
  • Fan kit fitted DONE
  • Intercooler out DONE
  • Exhaust flexi repair DONE
  • Wire up rear foglights using UK MR2 parts (indicator in instrument panel, proper toyota switch etc) DONE
  • New Oil & Water pumps DONE
  • New rear pads & discs DONE
  • Fit Brakes International refurbed rear brake calipers DONE
  • New heater controls, boot & fuel flap release & driver's carpet DONE
  • Gearbox bellhousing repair DONE
  • TRD torque mounts DONE
  • Fidanza flywheel fitted with ARP bolts DONE
  • Goodridge braided clutch line DONE
  • Goodridge braided brake lines DONE
  • Electric mirror control repair Investigated, spare control I've got is wrong one
  • Fit Walbro fuel pump
  • Alarm boot release Broken rear lock removed, pull release connected up in a much more sensible way than Toyota's & solenoid added, just needs cabling to the new fusebox
  • Side strip mounts repaired
  • Front Foglights reinstalled
  • Front bumper repair (fibreglass)
  • Reversing camera reinstalled
  • Purchase TD06 oil & water lines + new style TD06 adaptor
  • TD06 fitted
  • Engine bay cleanup (powder coated rocker cover + inlet manifold + chargecooler, hoses colour coordinated, some new gaskets & clean up oil leak)
  • Diagnose chargecooler leak Sad
  • Painted and stickered calipers
  • Fit new brake master cylinder, sliders & pins
  • Properly fix brake hoses to mounting points on car
  • Modify new seats with Waeco heater elements DONE
  • Fit new seats, including figuring out how to mount the seatbelt clips
  • Fit wiring loom + switches etc for new seats
  • 2 new front tyres + wheel alignment
  • New Alternator belt DONE, but needs tightening a little
  • New ECU water temp sensor
  • New aircon belt
Shame it's not really the weather for doing things to cars!!
20-10-2016, 04:05 AM #223
  • TD06 fitted
  • New aircon belt
21-10-2016, 07:17 AM
We don't use the wing mirror control on our MR2 - could we do a swap, if ours is the correct one - assuming you mean the one on the drivers door?
21-10-2016, 07:17 AM #224
21-10-2016, 07:21 AM
That's very kind of you - does yours have retracting mirrors?
21-10-2016, 07:21 AM #225
21-10-2016, 07:22 AM
It did, but there isn't room in the mirrors for the motor with all the electrics that are there for things like the indicator LED's.
21-10-2016, 07:22 AM #226
21-10-2016, 07:27 AM
Ah, mine doesn't so my control doesn't have the retract button. That's the problem I have at the moment, my spare (fully working) mirror control has a retract button on it too Sad Thanks anyway!
21-10-2016, 07:27 AM #227
22-10-2016, 04:23 AM
In my continuing mission to make my dash as stock as possible with all my extra toys fitted, a rev counter with factory security/alarm LED turned up this morning. Gonna move the LED for my Toad alarm to there instead of having holes drilled in my dashboard... that alarm is such a bodge fit!!
22-10-2016, 04:23 AM #228
28-10-2016, 07:38 AM
OK, have secured a new mirror controller courtesy of Leon on IMOC, and have got somewhere with wiring up the electric seats. The relay & fuses are located and wired in properly, the wiring is pulled through to the driver's side panel, the switch + LED are in the right place but not attached to anything yet. I still ahve to do anything to the passenger side, but that's simpler as it just involves taking the glovebox out (4 screws). While I was delving around in the dash I plugged in a stereo lead into the rear aux-in on my head unit so I don't have to keep plugging stuff in the front, which gets in the way of the gear stick.
I've decided how I'm going to do the security LED in the rev counter but it involves buying a new LED which I'll do next time I'm in MK and liberating some 3 pin fan connectors from a dead PC. I have found a MASSIVE old digital camera so I will be able to do photos for that bit.
28-10-2016, 07:38 AM #229
01-11-2016, 09:56 AM
Fitted a new ECU water temp sender today to cure my cold running problems - result is an instant fix. Lovely Smile Also put the dash back together following stripping it apart for the heated seat wiring and secured the HT leads down to the head like they're meant to be. Didn't start til about 2PM so by the time I was finished it was dark & raining - don't you just love working on cars outside!! Took a while because both the temp sender and HT leads are underneath the chargecooler core so all that had to come off, which is a bit complicated without splitting the coolant lines and having to drain, rebleed, etc etc.
I'll post some pics up of the old sender when I get time, you'll laugh Smile It's quite clear as to why it wasn't working Big Grin
01-11-2016, 09:56 AM #230
 6 Guest(s)
 6 Guest(s)
Views 873
31-10-2023, 10:05 PM
Views 1,458
08-10-2023, 03:59 AM
Views 5,918
06-10-2023, 02:58 AM
Views 3,084
04-10-2023, 03:52 PM
Views 21,927
10-09-2023, 07:50 PM
Replies 79
Views 4,220
03-09-2023, 10:30 AM
Views 1,921
17-05-2023, 11:25 AM
Views 6,360
05-05-2023, 01:09 PM
Views 855
18-03-2023, 01:09 PM
