Pages (76): Previous 123 24 25 26 2776 Next
04-11-2016, 11:50 AM
You might think that but I plugged it into the alarm today and it didn't work. I reckon the TOAD LED might be common anode where the Maplin LED is common cathode. Just gonna redo the board with the TOAD LED as I removed it in one piece.
ARGH and now I just ripped the boost gauge off the IC
Edit: Yep, as I thought the TOAD LED is common anode GRR. I am so mad about the boost gauge, it took me ages to get that right. Today is not going well.
Edited 16-12-2009, 09:42 PM by toxo.
04-11-2016, 11:50 AM #241
09-11-2016, 04:24 AM
It was COLD yesterday!!
Brake master cylinder changed, brakes much better. Unfortunately I forgot to take the handbrake off when bleeding the rears, schoolboy error, so they need bleeding again. Glued the boost gauge back in, new LEDs turned up so now my alarm LED works Big Grin Oh I found somewhere to buy a replacement screen for my digital camera too :thumbup: So more pics soon. Have also replaced the piece of trim on the dashboard that had holes in it for the alarm LED etc with an unbutchered one.
  • Amp board & subs reinstalled DONE
  • Speaker wire repair for driver's door components DONE
  • Alarm siren & engine bay switch working DONE
  • Alarm total closure DONE
  • HKS CAMP installed DONE
  • Omori 45mm boost gauge fitted in-dash DONE
  • HKS SSQV fitted DONE
  • Accessory Fuse & Relay box installed DONE
  • Fan kit fitted DONE
  • Intercooler out DONE
  • Exhaust flexi repair DONE
  • Wire up rear foglights using UK MR2 parts (indicator in instrument panel, proper toyota switch etc) DONE
  • New Oil & Water pumps DONE
  • New rear pads & discs DONE
  • Fit Brakes International refurbed rear brake calipers DONE
  • New heater controls, boot & fuel flap release & driver's carpet DONE
  • Gearbox bellhousing repair DONE
  • TRD torque mounts DONE
  • Fidanza flywheel fitted with ARP bolts DONE
  • Goodridge braided clutch line DONE
  • Goodridge braided brake lines DONE
  • Electric mirror control repair DONE, New controller fitted
  • Fit new brake master cylinder DONE
  • Modify new seats with Waeco heater elements DONE
  • New Alternator belt DONE, tightened
  • New ECU water temp sensor DONE
  • Fit Walbro fuel pump
  • Alarm boot release Broken rear lock removed, pull release connected up in a much more sensible way than Toyota's & solenoid added, just needs cabling to the new fusebox
  • Side strip mounts repaired
  • Front Foglights reinstalled
  • Front bumper repair (fibreglass)
  • Reversing camera reinstalled
  • Purchase TD06 oil & water lines + new style TD06 adaptor
  • TD06 fitted
  • Engine bay cleanup (powder coated rocker cover + inlet manifold + chargecooler, hoses colour coordinated, some new gaskets & clean up oil leak)
  • Diagnose chargecooler leak Sad Possibly done, found a loose jubilee clip while doing water temp sensor
  • Painted and stickered calipers
  • Fit new rear brake sliders & pins
  • Properly fix brake hoses to mounting points on car
  • Fit new seats, including figuring out how to mount the seatbelt clips
  • Fit wiring loom + switches etc for new seats
  • 2 new front tyres + wheel alignment
  • New aircon belt Bought, haven't fitted yet
Edited 21-12-2009, 03:37 PM by toxo.
09-11-2016, 04:24 AM #242
  • TD06 fitted
21-11-2016, 04:51 AM
I have decided to shelve the MR2 project for a bit. I need to concentrate on getting myself debt free this year, and that's not going to happen while all my cash is going into the Toyota money pit. I've not yet decided whether to keep the TD06 or to flog it and buy another turbo next year. I have bought the supporting components for most of the stuff listed above so I'll still finish off a good chunk of the list.
21-11-2016, 04:51 AM #243
21-11-2016, 05:24 AM
Sad
Sorry to hear that mate. But sometimes hard decisions are needed.
21-11-2016, 05:24 AM #244
Sad
21-11-2016, 06:44 AM
toxo I have decided to shelve the MR2 project for a bit. I need to concentrate on getting myself debt free this year, and that's not going to happen while all my cash is going into the Toyota money pit. I've not yet decided whether to keep the TD06 or to flog it and buy another turbo next year. I have bought the supporting components for most of the stuff listed above so I'll still finish off a good chunk of the list.
its a good plan mate, but i bet the odd extra mod will sneak in lol.
how big is a TD06? compared to a GT series?
21-11-2016, 06:44 AM #245
21-11-2016, 06:50 AM
TD06's are small and really efficient. About the same size as the Toyota CT2x series turbos but good for like twice the horsepower. My one has a 20g impellor wheel in it (largest one they do IIRC) and is an externally 'gated one as well so I've got the Tial wastegate to go with it for some screamer pipe action.
21-11-2016, 06:50 AM #246
21-11-2016, 07:37 AM
toxo TD06's are small and really efficient. About the same size as the Toyota CT2x series turbos but good for like twice the horsepower. My one has a 20g impellor wheel in it (largest one they do IIRC) and is an externally 'gated one as well so I've got the Tial wastegate to go with it for some screamer pipe action.
hmm, possibly a bit small for my use then? what sort of power is it rated for?
21-11-2016, 07:37 AM #247
21-11-2016, 07:38 AM
It's this one
http://www.atsracing.net/ats_racing_td06...er_kit.htm
ATS claim 250-500bhp @ fly with that turbo on the MR2. That's at some quite high pressures though.
21-11-2016, 07:38 AM #248
It's this one
21-11-2016, 08:21 AM
So how much would a 2nd hand one go for....... My Tubby is pretty well maxed out at the moment:thumbdown:
21-11-2016, 08:21 AM #249
21-11-2016, 08:27 AM
I'm not gonna say on here as I'm not a paid up Outlaw and am therefore not allowed to advertise things for sale on here!
21-11-2016, 08:27 AM #250
 7 Guest(s)
 7 Guest(s)
Views 873
31-10-2023, 10:05 PM
Views 1,458
08-10-2023, 03:59 AM
Views 5,918
06-10-2023, 02:58 AM
Views 3,084
04-10-2023, 03:52 PM
Views 21,928
10-09-2023, 07:50 PM
Replies 79
Views 4,220
03-09-2023, 10:30 AM
Views 1,921
17-05-2023, 11:25 AM
Views 6,360
05-05-2023, 01:09 PM
Views 855
18-03-2023, 01:09 PM
