JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications is200 oil water fead return pipe pickys
18-03-2019, 09:26 AM
This is the reason I ask:
[Image: is300.jpg]
This is an IS300 fuel rail. Note the end on the left is sealed.
[Image: is200.jpg]
This is an IS200 fuel rail. Note the bolt on the end that you can unscrew and replace with a fuel takeoff.
Like I said, the parts diagrams have been wrong before. But that's all the info I have to go on!
18-03-2019, 09:26 AM #21
[Image: is300.jpg]
[Image: is200.jpg]
john wan
18-03-2019, 09:38 AM
oooo cheeky was thinking tho that if i got a standard is300 fuel regulator because im only looking to get the same bhp as the is300 then surely that should do no? havnt looked into it properly might be talking outa mah ass dunno if the fueling system is the same will have to look about
john wan
18-03-2019, 09:38 AM #22
18-03-2019, 09:39 AM
Doesn't work like that! The injectors are larger for starters
18-03-2019, 09:39 AM #23
john wan
18-03-2019, 09:41 AM
ahh haaaa obviously what a knob ha ha ha :Fish:
john wan
18-03-2019, 09:41 AM #24
18-03-2019, 10:05 AM
It'll be good if the is200 has that bolt.
Can't remember myself as I never touched the standard fuel rail lol
18-03-2019, 10:05 AM #25
john wan
18-03-2019, 10:15 AM
Ill get hunting when I can get to the car an post up is the return just gravity? Or has the standard. Pump got a bit u can fit to if that makes sense
john wan
18-03-2019, 10:15 AM #26
john wan
18-03-2019, 10:52 AM
Had a realy quick look seems there's a bolt there from what I could see
john wan
18-03-2019, 10:52 AM #27
18-03-2019, 10:59 AM
The return line is sucked back by the fuel being removed front the tank creating a small vacuum.
18-03-2019, 10:59 AM #28
john wan
18-03-2019, 11:20 AM
Chears mate tis what I was going on about wasn't sure whether the tank would preasureise an run properly
john wan
18-03-2019, 11:20 AM #29
18-03-2019, 01:29 PM
No it's work exactly the same don't worry.
18-03-2019, 01:29 PM #30
Views 1,767
05-07-2023, 05:08 AM
Last Post by damtrx
Views 827
17-04-2023, 03:51 AM
Views 1,420
05-04-2023, 03:19 AM
Last Post by damtrx
Views 741
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 304
29-11-2022, 03:38 AM
Last Post by phaebo
Views 401
30-04-2022, 06:27 AM
Views 604
27-04-2022, 12:45 PM
Last Post by oedipus
Views 695
19-06-2021, 12:50 PM
