JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Head bolts
Head bolts
Head bolts
Jimbob-T-Lex
Moderator
1,674
17-05-2019, 03:58 AM
are the ones from ike the proper ones for the 1gfe engine or the 1jz/2jz ones because they are expensive compared to the 1jz/2jz one i found save £70???
Jimbob-T-Lex
17-05-2019, 03:58 AM #21
17-05-2019, 06:39 AM
They don't make them for the 1g engine. Check the arp website.
17-05-2019, 06:39 AM #22
Jimbob-T-Lex
Moderator
1,674
19-05-2019, 03:44 AM
so get the 1jz/2jz ones thanks Sparkystav!!!
Jimbob-T-Lex
19-05-2019, 03:44 AM #23
Jimbob-T-Lex
Moderator
1,674
02-11-2019, 05:14 AM
Right i got what i think is 1jz/2jz head stud kit with part number 203-4205 but these do not fit the 1gfe engine the only thing i can think is that these bolts are in the wrong box??? does anyone know the dimensions the arps should be?
Jimbob-T-Lex
02-11-2019, 05:14 AM #24
02-11-2019, 06:19 AM
why dont they fit mate? whats the issue, length, thickness?
02-11-2019, 06:19 AM #25
Jimbob-T-Lex
Moderator
1,674
02-11-2019, 06:32 AM
right mate i literally just had mains studs delivered and i test fitted them and they are fine but the head studs have the correct pitch but when compared to the original head bolts the diameter seems to be too large???? not sure whats going on lol
Jimbob-T-Lex
02-11-2019, 06:32 AM #26
Jimbob-T-Lex
Moderator
1,674
02-11-2019, 06:56 AM
right the head studs diameter is defin too big so i can only assume that these are the the wrong bolts in the correct box which is a pain as i got them off ebay from someone who never fitted them for £85 lol never fitted as they are wrong :Shooting: lmao
Jimbob-T-Lex
02-11-2019, 06:56 AM #27
02-11-2019, 10:08 AM
jimbob150385 right the head studs diameter is defin too big so i can only assume that these are the the wrong bolts in the correct box which is a pain as i got them off ebay from someone who never fitted them for £85 lol never fitted as they are wrong :Shooting: lmao
Can you measure the diameter?
Can't see why they would be different to the 1ggte ones as they use the same block. So you may be right and their just plain wrong.
02-11-2019, 10:08 AM #28
Jimbob-T-Lex
Moderator
1,674
02-11-2019, 11:22 AM
just a check mate it is the 1jz/2jz ones you used?? lol they say 7/16 diameter on the bit of paper inside the box but ill comfirm tomorrow and measure
Jimbob-T-Lex
02-11-2019, 11:22 AM #29
02-11-2019, 11:46 AM
Toymods is where I got the info mate:
http://www.toymods.org.au/forums/tech-co...tions.html
02-11-2019, 11:46 AM #30
Views 316
16-09-2020, 08:21 AM
Views 359
28-06-2019, 12:32 AM
Views 740
03-05-2019, 06:00 AM
Views 560
28-10-2018, 03:56 AM
Replies 23
Views 1,431
24-04-2018, 03:03 AM
Last Post by jimxms
Views 336
21-04-2018, 12:21 PM
Last Post by Andy-R.
Views 562
10-12-2017, 03:22 PM
Last Post by Phil01
Views 1,933
06-11-2017, 12:53 AM
Views 390
12-07-2017, 09:56 PM
Last Post by TimmyK
