JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Fitting the E-Manage Ultimate
S
23-05-2019, 10:43 PM
Ah poop! Well I'm still going to try and use the Greddy one!
Thanks again for the help Stav!
S
23-05-2019, 10:43 PM #21
S
25-05-2019, 11:39 AM
Stav, can you confirm that when the Greddy instructions say CH6 on the ignition loom they mean #6 on the lexus ecu pin out diagram?
I've wired it all up and it has started but the Greddy Unit is saying that ignition inputs 1 through 6 are incorrect!
I've triple checked my wiring and the jumpers in the unit but I can't find the cause of the problem!
S
25-05-2019, 11:39 AM #22
25-05-2019, 12:30 PM
No mate its not. Needs to be in firing order.
153624
Too young, too old, just right. Lol so 1 on greddy to 1 on lex, 2 on greddy to 5 on lex. Etc
25-05-2019, 12:30 PM #23
153624
Ps have you soldered or crimped?
25-05-2019, 12:30 PM #24
S
25-05-2019, 12:38 PM
Sparkystav No mate its not. Needs to be in firing order.
153624
STAV - I literally dont know what Id do without you!
Ive soldered the connections.
S
25-05-2019, 12:38 PM #25
153624
S
25-05-2019, 12:52 PM
also is it the inputs AND the outputs that need to be in firing order? because the fault window on the Emanage software only said input?
S
25-05-2019, 12:52 PM #26
25-05-2019, 01:54 PM
Yeah both mate. Glad you're soldered an used the stupid crimps that come with the kit
25-05-2019, 01:54 PM #27
S
25-05-2019, 11:09 PM
Thanks Stav, I'm going to go rep someone else just so I can rep you again!
Lifesaver! I would never have worked that out myself!!
S
25-05-2019, 11:09 PM #28
S
26-05-2019, 03:51 AM
Hopefully my final question!
Where does the MAP sensor get plumbed into? Same place as a boost gauge?
S
26-05-2019, 03:51 AM #29
S
26-05-2019, 04:11 AM
153624
Just to confirm its:
Lexus ECU Pin #: 153624
Greddy CH#: 123456
Is that correct?
S
26-05-2019, 04:11 AM #30
153624
Greddy CH#: 123456
Is that correct?
Views 597
27-02-2020, 06:01 AM
Views 537
16-06-2019, 10:21 AM
Last Post by S
Replies 36
Views 2,013
14-10-2018, 11:50 PM
Last Post by Bandit
Replies 23
Views 1,738
12-06-2018, 06:03 AM
Last Post by lookatmybiceps
Replies 74
Views 4,111
05-04-2018, 08:11 AM
Last Post by bounty`
Views 1,493
01-01-2017, 06:54 AM
