JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Is200 Door Lock system
rob
23-07-2016, 07:28 AM
i would say scary is a massive overstatement TBH.... u just use the lock button next to the handle.
rob
23-07-2016, 07:28 AM #21
23-07-2016, 09:03 AM
rob i would say scary is a massive overstatement TBH.... u just use the lock button next to the handle.
It doesnt work if you dont have power! the solenoids that lock the doors wont work to unlock the door! :bored:
23-07-2016, 09:03 AM #22
23-07-2016, 09:22 AM
I haven't tried disconnecting the battery (I hate it when I have to put all the settings back into my head unit !), but there's no solenoid/motor noise when I push that black/red button to manually unlock a door, I'm pretty sure that's just a cable operating the lock. At least that's how it seems on my car ?
23-07-2016, 09:22 AM #23
rob
23-07-2016, 11:03 AM
Bandit It doesnt work if you dont have power! the solenoids that lock the doors wont work to unlock the door! :bored:
rubbish! - moving the small locking knob by the door handle is a mechanical action, no solenoids involved.
rob
23-07-2016, 11:03 AM #24
rob
23-07-2016, 11:08 AM
Marsdendean Ill try mine when i go for fuel.
Ill sit in the car, press it once and see if i can open any doors, and then press it twice!!!
why on earth would anyone press the key fob whilst they are in the car????
it appears people are confusing this topic by talking about 2 completly different actions.
1. being in the car and then using the key fob to lock the doors -which doesnt make any sense at all :confused:
2. using the interior central locking button and thn trying to open the door without unlocking the door first, which again doesnt make any sense... you wouldnt try to open your house door without unlocking it would you....
rob
23-07-2016, 11:08 AM #25
23-07-2016, 11:12 AM
In reference to point 1, this is just a test (which I again forgot to do today) just to see how the deadlocks behave - in normal use I can't imagine anyone actually doing that :laugh:
Not sure about point 2 though, I agree with you that if you've just locked the doors with the interior lock button, they will just unlock again if you slide the lock the other way - I've actually tried that before when I've had the battery disconnected.
23-07-2016, 11:12 AM #26
23-07-2016, 11:25 AM
rob rubbish! - moving the small locking knob by the door handle is a mechanical action, no solenoids involved.
Huh
Edited 03-09-2009, 09:20 PM by Bandit.
23-07-2016, 11:25 AM #27
Huh
23-07-2016, 11:49 AM
the double locking from what i gather requires all 5 wires so it must sense the position of the lock will further investigate at the weekend my plan is coming together:w00t:
23-07-2016, 11:49 AM #28
23-07-2016, 12:26 PM
Rabster the double locking from what i gather requires all 5 wires so it must sense the position of the lock will further investigate at the weekend my plan is coming together:w00t:
Are you possibly coming up with an autolock? Rolleyes
23-07-2016, 12:26 PM #29
23-07-2016, 01:12 PM
parthiban Are you possibly coming up with an autolock? Rolleyes
i know how to do that :w00t: but its not cheap its about £100 quid and requires a little bit of hunting around for a few wires like the VSS wire
butwill allow you to set the speed to lock the doors and unlock the doors either at ignition off or under a certain speed if memory serves
Rabs
23-07-2016, 01:12 PM #30
Rabs
 3 Guest(s)
 3 Guest(s)
Views 252
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 928
28-05-2023, 02:46 PM
Last Post by bigdave1701
Replies 47
Views 3,023
08-12-2022, 09:37 AM
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 737
23-03-2021, 07:29 AM
Last Post by kaykay
Views 336
15-09-2020, 02:23 PM
Replies 31
Views 1,825
25-07-2020, 07:50 AM
Replies 103
Views 5,815
31-03-2020, 07:02 AM
Last Post by Barry
Views 355
30-10-2019, 05:26 AM
