Pages (17): Previous 1 2 3 4 517 Next
03-04-2020, 10:47 AM
dimis In my last setup (almost 2 years) I used 2zz yellow injectors (310cc) and a 148mm pulley. The car worked fine together with the e-manage.
Which should be coming my way some day Big GriniscoStu:
03-04-2020, 10:47 AM #21
Daniel N
03-04-2020, 10:50 AM
Ok understood:thumbup1:
Daniel N
03-04-2020, 10:50 AM #22
mark3
03-04-2020, 11:00 PM
If the charger pulley is changed for one of a larger diameter won't the charger be turning slower and therefore make less boost?
From my Samsung S4
mark3
03-04-2020, 11:00 PM #23
From my Samsung S4
S
03-04-2020, 11:09 PM
mark3 If the charger pulley is changed for one of a larger diameter won't the charger be turning slower and therefore make less boost?
From my Samsung S4
Supercharger boost is dictate by the ratio between the pulley on the supercharger and the pulley on the engine.
To increase boost you either:
reduce the size of the pulley on the supercharger
Or
Increase the size of the pulley on the engine.
S
03-04-2020, 11:09 PM #24
From my Samsung S4
Or
04-04-2020, 12:48 AM
If some one can make custom pulleys for the actual charger that removes the clutch I think there's a market.
04-04-2020, 12:48 AM #25
S
04-04-2020, 01:18 AM
Sparkystav If some one can make custom pulleys for the actual charger that removes the clutch I think there's a market.
Funny you should mention that ....
S
04-04-2020, 01:18 AM #26
04-04-2020, 02:03 AM
If I could like a post.....
04-04-2020, 02:03 AM #27
S1SOFT
10-04-2020, 02:44 AM
Hello.
Sorry for my English. Need help.
I installed the pulley 145mm. I read the forum here talking to install injectors 1ZZ-FE(green 23250-22040) or 2ZZ-GE(yellow? 23250-22030).*
So what are the best bet 1zz or 2zz?
These injectors will be established and will stand on the engine with no problems and changes? Did not have to nag?
S1SOFT
10-04-2020, 02:44 AM #28
Hello.
phaebo
10-04-2020, 03:16 AM
I have the 1zz green injectors installed. They will fit perfectly. I did use new o-rings. The ones i used were both oem lexus is200 injector o rings.
Still waiting for my 145 mm pulley so i cant tell you how it feels
phaebo
10-04-2020, 03:16 AM #29
phaebo
10-04-2020, 03:20 AM
If you go for the green 1zz injectors please make sure that there is a black plastic cap on the under side of the injectors. If there isnt it will not seal good enough.
I use the 1zzfe green injectors with patrick blackbox and works perfect
phaebo
10-04-2020, 03:20 AM #30
Views 808
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 321
01-07-2022, 12:38 PM
Last Post by lexusdaydreaming
Views 546
14-09-2021, 07:43 AM
Last Post by P.Lindblom
Views 755
09-08-2021, 10:35 PM
Last Post by Jimbob-T-Lex
Views 433
26-07-2021, 11:20 AM
Last Post by reganlives
Views 464
30-03-2021, 03:26 PM
Views 403
13-03-2021, 05:38 PM
Last Post by deccie22
Views 669
17-09-2020, 03:53 PM
Last Post by gsitlv
