JapCarForum Cars, Cars, Cars! General Car Maintenance yet more problems with the scooby :(
Pages (7): Previous 1 2 3 4 57 Next
john wan
10-11-2021, 11:49 AM
Get to spraying stuff first mate if you don't need to remove it don't it's a proper nightmare
john wan
10-11-2021, 11:49 AM #21
bambam
10-11-2021, 11:52 AM
Right ok ill take your word for it lol they are not the easiest cars to work with, i need to get spark plugs out to see what state there in and that dont look like no walk in the park niether lol
bambam
10-11-2021, 11:52 AM #22
john wan
10-11-2021, 12:10 PM
You'll need 12mm spanner and obviously a small plug socket and Small extension bar for it.
First take the two 10mm bolts holding the washer bottle out then lift the bottle up out of the way you have to take the power plug off first then undo the coil packs pull out slip the socket inside then put the extension on then the ratchet undo to finger tip tight then take off the ratchet an undo the rest of the way by fingers obviously reverse to put back but remove the rubber grommet from the plug socket before you start or you will tighten it all up an not be able to get the socket out ha ha.
On the other side take the induction kit and brackets off removing these two bits first will save your knuckles
john wan
10-11-2021, 12:10 PM #23
bambam
10-11-2021, 12:19 PM
Jesus christ may aswell just drop the engine lol
bambam
10-11-2021, 12:19 PM #24
john wan
10-11-2021, 08:22 PM
Ha ha ha ha it's not that bad you will do it a he'll of a lot quicker doing it this way and there will be a lot less blood ha ha ha
john wan
10-11-2021, 08:22 PM #25
bambam
12-11-2021, 04:44 AM
OH MY DAYS!! i hate this car can anyone tell me where the obd port is and what connector to buy for it??? :angry::cursing:
bambam
12-11-2021, 04:44 AM #26
john wan
12-11-2021, 04:47 AM
I'd is on drivers side by the bonnet release bud
john wan
12-11-2021, 04:47 AM #27
bambam
12-11-2021, 04:51 AM
Is it a yellow 3 pin connector?
bambam
12-11-2021, 04:51 AM #28
john wan
12-11-2021, 05:10 AM
Hmm post a picky up mate
john wan
12-11-2021, 05:10 AM #29
bambam
12-11-2021, 08:14 AM
Sorry mate... i found it, wasnt that one but i was yellow, the car cut out on me earlier and was dead absolutley nothin happened when i turned the key then all of a sudden just burst into life, then happened agean when i found my obd port, i pulled apart my dash and found a wire from the turbo timer had frazzled so ive took it out completely see what happens... also i took my afm off and cleaned it out and hasnt helped the boost problem Sad
bambam
12-11-2021, 08:14 AM #30
Views 1,635
21-04-2019, 01:15 AM
Views 503
07-03-2019, 05:02 AM
Views 775
17-07-2018, 03:14 PM
Last Post by purple samurai
Views 987
13-07-2018, 04:36 AM
Last Post by CherylTDI
Views 577
30-08-2016, 04:12 AM
