JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza HID not working
HID not working
HID not working
aaronabbott
02-09-2016, 08:26 AM
hmmmmm,im not sure if it makes a difference tbh but the voltage that goes to them when you switch the ign on might cause them the break,thats why now i only use auto when im driving
aaronabbott
02-09-2016, 08:26 AM #21
02-09-2016, 10:04 AM
aaronabbott hmmmmm,im not sure if it makes a difference tbh but the voltage that goes to them when you switch the ign on might cause them the break,thats why now i only use auto when im driving
I've heard that before, but I'm lazy Blush
However if you had an IS300 with OEM HIDs, can you still not leave them on auto? I've swapped them over to the halogens for the MOT tomorrow anyway so will sort it out after that.
Btw, are front fogs part of the MOT? Just noticed the drivers fog doesn't work either - bizarre as I never use them, but will have to get them to replace that if it is part of the MOT.
02-09-2016, 10:04 AM #22
02-09-2016, 11:04 AM
Dont think the front fogs are part of the MOT mate, i've never seen them check mine in the past? Think its only the rear ones they check?? Smile
02-09-2016, 11:04 AM #23
02-09-2016, 12:50 PM
Bandit Dont think the front fogs are part of the MOT mate, i've never seen them check mine in the past? Think its only the rear ones they check?? Smile
Cool, won't say anything then, I'm sure if it's needed they'll let me know Smile
02-09-2016, 12:50 PM #24
spikes
02-09-2016, 01:08 PM
on the instructions i had with my hid kit it tells you to avoid starting the car with the lights on :wink:
spikes
02-09-2016, 01:08 PM #25
Purvesh
02-09-2016, 02:33 PM
parthiban Just popped out during lunch and swapped them over, driver's side still doesn't work - checked fuses and they're fine, so must be the ballast?
What's the best plan now? Looking at the HIDs direct site as mentioned earlier, are their products decent quality? Could just replace the ballast for £20 then........
However, a whole new 50W kit from them just costs £64 - given this one just failed, there is the possibility that the other may fail as soon as replace this one - in which case I may as well just replace the whole lot, especially as I wanted to change bulb colour anyway........
What do you all recommend? And who should I buy from?
Sounds like the ballast. I've bought two kits from HID Direct (one for my uncle) both 8000k and only had the problem with the ballast which they quickly resolved.
Not sure I'd personally go all the way down to 4300k again, but if that's what you want then your probably getting a new kit (with the same style ballasts).
[COLOR="DarkSlateBlue"]--------------------
IS200SE, Astral Black, Auto, DVD Sat Nav, TTE Front Bumper, TRD rear skirt, TRD side skirts, IS300 Lip spoiler with integrated brake light, 18" Inovit Hunter Alloy wheels with Toyo T1-S 225/40 tyres, Dark Lexus Fogs and Headlights, LS430 side repeaters, Sport Auto Pedals, Lexus floor mats with custom decals, 8000k HIDs, Xenon LED sidelights, GromAudio Ipod lead, WIM calibrated geometry...
[/COLOR]
Purvesh
02-09-2016, 02:33 PM #26
[/COLOR]
02-09-2016, 09:36 PM
Bandit i was lead to believe that any lighting unit fitted to the car ie: the fog lamps have to work.
Here is a mot list on what lights are checked.
This includes all the following in working order :
Headlights - Low beam & High beam
Sidelights
Brake lights
Side repeaters
No. plate lights
Drivers side Fog light
Hazard warning lights or emergency lights
Left and right, front and rear indicators
Rear number plate light
02-09-2016, 09:36 PM #27
Sidelights
Brake lights
Side repeaters
No. plate lights
02-09-2016, 09:40 PM
Not sure mate, just know they have never checked them on any of my cars that i've had? maybe its just the mot inspector being lazy as i've used the same place for a few years now :Chair:
02-09-2016, 09:40 PM #28
02-09-2016, 09:54 PM
I am not sure what sort of lights are legal in what unit.
It maybe worth checking :
http://www.regalautobulbs.co.uk/faq.php
Edited 15-10-2009, 07:31 AM by Lexusboy.
02-09-2016, 09:54 PM #29
02-09-2016, 10:41 PM
Purvesh Sounds like the ballast. I've bought two kits from HID Direct (one for my uncle) both 8000k and only had the problem with the ballast which they quickly resolved.
Cool, I'll check out the link Dan mentioned if he can find it, otherwise might go with them then. How do you mean wouldn't go down to 4300K again? Do you mean just in terms of colour? If so, that's exactly what I want, it's getting a bit chavvy to have the bluer lights, so just want it to look OEM (plus technically I'd have more light on the road which is no bad thing)
Lexusboy Bandit i was lead to believe that any lighting unit fitted to the car ie: the fog lamps have to work.
Sidelights
Brake lights
Side repeaters
No. plate lights
Based on that list though we're only talking about the rear fogs aren't we (that's why it just says drivers side fog light?)
Marsdendean can sidelights class as LED lights? My mot is months away, but i know a couple of people have ditched the sidelight bulbs for the LED strips
Yes I'm pretty sure you just need to have some form of working sidelight, I doubt they'd be bothered whether or not it is as it was from the factory.
02-09-2016, 10:41 PM #30
Sidelights
Brake lights
Side repeaters
No. plate lights
Views 440
28-06-2019, 10:43 AM
Last Post by purplewitch
Views 802
28-09-2018, 11:44 AM
Views 610
18-03-2018, 07:56 AM
Last Post by danielson
Views 456
06-05-2017, 01:04 PM
Views 1,204
18-01-2017, 10:52 AM
Replies 33
Views 1,534
05-01-2017, 12:30 AM
Last Post by kam05
Views 668
04-06-2016, 11:22 AM
Last Post by Andy-R.
