JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Front fog not working.
Andy-R.
26-05-2016, 08:55 AM
My front fogs have stopped working, have checked the fuse and it's fine, not checked the bulbs yet but not sure if both would go at the same timeHuh or whether they've blown seperately as i've only just noticed, never use the fogs but it'll be an MOT issue so any clues if it's not the bulbs? maybe the control stork?
Cheers.
[Image: Lf9Nl.jpg]
Andy-R.
26-05-2016, 08:55 AM #1
Cheers.
[Image: Lf9Nl.jpg]
26-05-2016, 09:30 AM
Don't think front fogs will be an MoT issue, front fogs aren't a requirement to be fitted on a car.
26-05-2016, 09:30 AM #2
26-05-2016, 09:32 AM
Does the front fog warning light on the dash come on when you switch them on ? Do the tail lights work ok ? How about the relay, there's a front fog relay involved too.
26-05-2016, 09:32 AM #3
Andy-R.
26-05-2016, 09:47 AM
Everything else works, no warning lights nothing, it's probably the bulbs but just wanted a heads up if it's not, as for the MOT I thought they had to be working if there fittedHuh
[Image: Lf9Nl.jpg]
Andy-R.
26-05-2016, 09:47 AM #4
[Image: Lf9Nl.jpg]
26-05-2016, 09:50 AM
I'm pretty sure it's just rear fog lamps, see the MoT Tester's manual here.
The front fogs are notorious for getting corroded, you might want to see how the back of the connectors looks. Also perhaps test there with a multimeter to see if you've got any current getting there.
If the light isn't coming on in the dash then that's kind of odd, may be worth checking the relay.
26-05-2016, 09:50 AM #5
Andy-R.
26-05-2016, 10:06 AM
Cheers Stevie.
[Image: Lf9Nl.jpg]
Andy-R.
26-05-2016, 10:06 AM #6
Cheers Stevie.
[Image: Lf9Nl.jpg]
Andy-R.
03-06-2016, 03:18 AM
Ok update, still not working it's not the fuse, not the bulbs, not the control stork because the the little light that says the fogs are on comes on when I turn the switch, checked the conections they seem fine so i'm stumped, i've nothing to test if there's any power going them so don't really know what to do now, also does anyone know if the front fogs are for some strange reason linked to the light in the boot because that's stopped working aswell and thats not the bulb either.
[Image: Lf9Nl.jpg]
Andy-R.
03-06-2016, 03:18 AM #7
[Image: Lf9Nl.jpg]
aaronabbott
03-06-2016, 03:23 AM
ive been told that they corrode behind the light andy so check the connections behind
aaronabbott
03-06-2016, 03:23 AM #8
Andy-R.
03-06-2016, 03:37 AM
aaronabbott ive been told that they corrode behind the light andy so check the connections behind
Done that matey.
[Image: Lf9Nl.jpg]
Andy-R.
03-06-2016, 03:37 AM #9
Done that matey.
[Image: Lf9Nl.jpg]
aaronabbott
03-06-2016, 03:43 AM
give it a whack with a impact therapy tool Big Grin (otherwise known as a big hammer)
aaronabbott
03-06-2016, 03:43 AM #10
Views 204
01-07-2020, 04:42 AM
Views 623
02-08-2019, 08:39 AM
Last Post by jasons
Views 309
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 328
19-07-2019, 12:48 PM
Last Post by Chris0121
Views 385
28-06-2019, 10:43 AM
Last Post by purplewitch
Views 835
01-04-2019, 04:02 AM
Last Post by lookatmybiceps
Views 360
15-01-2019, 05:15 AM
Last Post by avi_444
Views 1,138
28-11-2018, 10:22 AM
Last Post by sprinter2012
Views 724
28-09-2018, 11:44 AM
