fitting a hks FCD- a guide or directions??
Can you do an ECU reset mate? by removing the ECTS and EFI fuse located in the fuse box under the bonnet? if you pull them both out and wait for around 30-60 seconds it should clear all fault data stored on the ecu? which should turn off the light?
Has my FCD set at number 9 mate, :thumbup1:
ETCS fuse isnt it?
Just for information mate, the lower the FCD the more leaner its making it,
so setting 12 is like its not there, and one is very very dangerous to set it to
There's a guide to resetting the ECU, with pics of where the fuses are, here.
Is it all sorted now ?
Bandit My wiring was different too when i did mine, and was a bit of a pain to figure out, but with a lot of help from Stav,, i sorted it out..
On mine the White and yellow FCD wires went to Block E5 which was a Green wire with a Red stripe and i cut this wire,
Then the yellow wire from the FCD connected towards the ECU and the White wire coming out of the FCD connected to the wire going away from the ecu, both connected to the Green wire with the Red stripe?
So you do need to cut just one wire!
Great news :thumbup:
