JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE SC pipework size???
24-11-2016, 09:01 AM
Marsdendean Moley - are you really sure that 59mm-63mm clamps will fit 60mm hoses Big Grin
Em yes :Fish:
24-11-2016, 09:01 AM #21
Em yes :Fish:
rob
27-11-2016, 09:21 AM
unless my SC is different from everyone elses the pipework sizes in the listing are incorrect!!
the bypass pipe is 38mm and the main pipework is 50mm!!! NOT 50mm and 60mm as listed.
so now i have to order another set of tubing......great! i may as well stick the incorrect size tubes up my **** for all the good its going to do me. rant over.
rob
27-11-2016, 09:21 AM #22
27-11-2016, 09:40 AM
gutted mate,
hope you get the correct parts and im sure no one meant to deceive you
27-11-2016, 09:40 AM #23
gutted mate,
27-11-2016, 09:57 AM
Bad news mate hope you can find a cheap replacement.
Can you resell what you have?
27-11-2016, 09:57 AM #24
27-11-2016, 09:58 AM
Sorry to hear that Rob. Have you got one of the very early charger kits ?
27-11-2016, 09:58 AM #25
rob
27-11-2016, 11:00 AM
its a mid age kit but it looks no different to any other kit i have ever seen.
ill just have to order another set of tubing i guess. wont be worth sending the tubes back as im in CH now and the post will be more than the tubes.
so can someone now please measure the pipework:confused:
rob
27-11-2016, 11:00 AM #26
27-11-2016, 12:49 PM
I'll measure mine tomorrow if you want. Do you want the pipes measured or the hoses ??
27-11-2016, 12:49 PM #27
rob
28-11-2016, 04:16 AM
i guess i know what happened....
the wall thickness of the silicone tubing is about 5mm so i guess the size of the silicone tubing was measured and not the pipework and then that would make sense with regard to the sizes listed.
It would also make sense why dimis used reducers and why mole said the 60mm clamps fit.
50mm pipework 5mm silicone wall =60mm overall thickness.
**** good thing i didnt buy clamps as well isnt it!
so know anyone that needs 60mm(inside) tubing???
moley: nah no need mate from my side but might be of some use to someone else in the future to confirm that the kits didnt have a pipework size change at some point.
rob
28-11-2016, 04:16 AM #28
29-11-2016, 12:04 AM
Straight bits of silicone hose aren't that expensive. But when you start looking at reducers, bends, or custom-shaped bits, it gets a lot more expensive.
29-11-2016, 12:04 AM #29
rob
29-11-2016, 04:49 AM
no its not expensive, its about £25 for 1 metre but its more the hassle having to re order stuff now and get it posted over to me ( its mental prices over here!). ill start looking for reducers etc as well now.
rob
29-11-2016, 04:49 AM #30
Views 354
16-09-2020, 08:38 AM
Last Post by philip_98
Views 742
18-09-2019, 10:35 AM
Views 511
17-12-2018, 10:18 AM
Last Post by S
