JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lack of power
Lack of power
Lack of power
01-04-2017, 11:17 AM
Phil01 ISC, idle speed control valve??
Is there one on the IS200 ?
01-04-2017, 11:17 AM #21
Phil01
01-04-2017, 11:32 AM
not 100% sure steve, I will look at the throttle body, there must be as wot controls the idle up??
My car always ticks over at 500rpm when hot
Phil01
01-04-2017, 11:32 AM #22
01-04-2017, 11:59 AM
I thought it was done by the ECU rather than just a valve on the IS200, but I am probably wrong !
Only 500rpm idle ? That sounds low to me. The online manual says 650rpm +- 50
01-04-2017, 11:59 AM #23
spikes
01-04-2017, 12:07 PM
think autos tick over lower than a manual
spikes
spikes
01-04-2017, 12:07 PM #24
spikes
01-04-2017, 02:28 PM
Partiban I'm having the same problem mate although mine has stalled a few times, same as yours it happens when coming to a stop. Im hoping it's a case of the air filter being dirty, bought a k&n filter cleaning kit a few weeks ago, will let you know how it runs once I've cleaned it
01-04-2017, 02:28 PM #25
01-04-2017, 09:52 PM
Wonder if the TPS needs a bit of adjustment? have heard/read in the past that people have had this type of problem and have either replaced the Throttle position sensor or adjusted it to improve the idle speed?
01-04-2017, 09:52 PM #26
01-04-2017, 11:51 PM
I hadn't actually noticed the low idle speed until yesterday when the car felt like it was about to stall, but could that be the cause of the power problems as well? Or am I looking at two different problems?
@Shahz: Yep that sounds pretty similar, do you have the same problem of it not having power for a bit on acceleration as well?
01-04-2017, 11:51 PM #27
01-04-2017, 11:54 PM
Difficult to say really. It could be the same thing causing both problems, or two unrelated things. If they both started happening at the same time, they're a lot more likely to be related.
01-04-2017, 11:54 PM #28
01-04-2017, 11:58 PM
Chris is that something that would have been touched /adjusted following the cambelt replacement as ive always felt the idle speed was a little low following the 60k service.......also k&n filter was put in......just wondering when did you install your k&n Parth and when did you clean it last??
01-04-2017, 11:58 PM #29
02-04-2017, 01:05 AM
Not sure if lexus adjust it/check at a service guys, but it can be adjusted to lift/lower the idle speed?
it has to be moved in very slight increments though to adjust it?
02-04-2017, 01:05 AM #30
Views 295
06-01-2020, 07:01 PM
Replies 25
Views 1,128
14-03-2019, 01:04 PM
Last Post by is300_dino
Replies 23
Views 1,336
29-01-2019, 03:11 PM
Last Post by jomo
Views 375
07-09-2018, 11:53 AM
Views 610
18-01-2018, 04:06 AM
Last Post by LEX11S
Views 977
25-10-2017, 08:18 AM
Last Post by reganlives
Replies 26
Views 1,158
04-10-2017, 12:10 PM
Views 360
28-02-2017, 09:59 AM
Last Post by ibby
Views 410
26-01-2017, 10:08 AM
Replies 24
Views 1,041
07-06-2016, 07:06 AM
Last Post by russelllinn
